NAOMI e NAOMI2 su Batocera 41 e CRT 15 Khz - non si avviano
emanueleguidetti
Città: Pistoia
Grazie Ricevuti: 5 volte
Messaggio da emanueleguidetti »
Buongiorno,
vorrei sapere se è possibile far funzionare NAOMI su CRT 15 Khz con Batocera.
Ho provato a mettere BIOS e una o due roms per sistema ma non riesco ad avviare nessuno dei due sistemi.
Ho provato a cambiare emulatore e forzare una risoluzione.
Non riesco a trovare un log di Batocera che mi aiuti a capire perchè non si avviano.
In "es_launch_sterr.log" vedo questo dove noto "00:01:001 ui/gui.cpp:578 E[COMMON]: Flycast has stopped: Unknown game":
2025-11-20 07:29:59,818 ERROR (emulatorlauncher.py:500):runCommand 00:00:000 sdl/sdl.cpp:734 N[RENDERER]: Monitor refresh rate: 30 Hz (641 x 480)
00:00:022 ui/gui.cpp:330 N[RENDERER]: Screen DPI is 96, size 641 x 480. Scaling by 1.00
00:00:743 rend/gles/gles.cpp:637 N[RENDERER]: OpenGL version 4.3
00:00:743 rend/gles/gles.cpp:638 N[RENDERER]: Vendor 'NVIDIA Corporation' Renderer 'GeForce GT 425M/PCIe/SSE2' Version '4.3.0 NVIDIA 390.157'
00:00:859 sdl/sdl_gamepad.h:179 N[INPUT]: SDL: Opened joystick 0 on port 0: 'ASD JammASD Player 1' unique_id=sdl_joystick_0
00:00:859 sdl/sdl_gamepad.h:179 N[INPUT]: SDL: Opened joystick 1 on port 1: 'ASD JammASD Player 2' unique_id=sdl_joystick_1
00:00:859 hw/mem/addrspace.cpp:431 N[VMEM]: Info: nvmem is enabled
00:00:879 hw/mem/addrspace.cpp:463 N[VMEM]: BASE 0x7f49f0cf0000 RAM(16 MB) 0x7f49fccf0000 VRAM64(8 MB) 0x7f49f4cf0000 ARAM(2 MB) 0x7f4a10cf0000
00:00:890 hw/mem/addrspace.cpp:431 N[VMEM]: Info: nvmem is enabled
00:00:925 hw/mem/addrspace.cpp:463 N[VMEM]: BASE 0x7f49f0cf0000 RAM(32 MB) 0x7f49fccf0000 VRAM64(16 MB) 0x7f49f4cf0000 ARAM(8 MB) 0x7f4a10cf0000
00:01:001 ui/gui.cpp:3487 E[BOOT]: Unknown game
00:01:016 sdl/sdl_gamepad.h:573 N[INPUT]: Resetting SDL gamepad to default: 0 1
00:01:183 sdl/sdl_gamepad.h:425 N[INPUT]: SDL: Joystick 'ASD JammASD Player 1' on port 0 disconnected
00:01:206 sdl/sdl_gamepad.h:425 N[INPUT]: SDL: Joystick 'ASD JammASD Player 2' on port 1 disconnected
X Error of failed request:  BadName (named color or font does not exist)
  Major opcode of failed request:  139 (RANDR)
  Minor opcode of failed request:  11 (RRQueryOutputProperty)
  Serial number of failed request:  29
  Current serial number in output stream:  29
Che ne pensate?
Grazie!
SuperMagoAlex
Città: LaSpezia
Grazie Inviati: 12 volte
Grazie Ricevuti: 40 volte
Re: NAOMI e NAOMI2 su Batocera 41 e CRT 15 Khz - non si avviano
Messaggio da SuperMagoAlex »
i bios li hai messi ? comunque sono giochi che a 15khz ti bruciano gli occhi, vanno giocati su monitor a 31khz in 640x480p
emanueleguidetti
Città: Pistoia
SuperMagoAlex ha scritto:i bios li hai messi ? comunque sono giochi che a 15khz ti bruciano gli occhi, vanno giocati su monitor a 31khz in 640x480p
Si, messo il Bios Naomi e Naomi2.
Capisco che Naomi non nasce per funzionare sul mio monitor ed infatti vorrei capire se non funziona proprio per questo motivo o c'è altro....
Grazie per l'aiuto!
Inviato dal mio SM-S908B utilizzando Tapatalk
SuperMagoAlex
Città: LaSpezia
Non ti funziona per altri motivi, ad esempio la versione del bios o rom non compatibili con la tua versione di Batocera.
Il problema è che poi ti gireranno in 480i e la resa a video sarà pessima.
emanueleguidetti
Città: Pistoia
SuperMagoAlex ha scritto:Non ti funziona per altri motivi, ad esempio la versione del bios o rom non compatibili con la tua versione di Batocera.
Grazie. Purtroppo per mia ignoranza non capisco il motivo...
Rockman84
Città: Mondovi
Grazie Inviati: 143 volte
Grazie Ricevuti: 110 volte
Messaggio da Rockman84 »
Ciao, partirei sempre dal linkare le wiki di Batocera relative al Naomi ed al Naomi 2
https://wiki.batocera.org/systems:naomi
https://wiki.batocera.org/systems:naomi2
Occhio al formato delle roms ed ai bios necessari per farle partire
Rockman84 ha scritto: 20/11/2025, 18:06 Ciao, partirei sempre dal linkare le wiki di Batocera relative al Naomi ed al Naomi 2
questo è l'atteggiamento giusto!!! wiki prima di tutto!
Rockman84
Città: Mondovi
Ti linko anche un paio di video guide fatte bene, seppur relative a versioni di Batocera più vecchie della tua:
emanueleguidetti
Città: Pistoia
Grazie a tutti per le info.
Giuro che prima di spammare i miei problemi studio, leggo le wiki, le guide, cerco di studiare i log.... :-)
Ho risolto il problema: le ROMS non compatibili.... Nessuna di quelle che avevo provato...
Adesso ho però scoperto che questi sistemi hanno bisogno di una bella potenza di calcolo ....che non ho! :-)
Rockman84
Città: Mondovi
Ottimo! Felice tu abbia risolto!
In quanto alla potenza richiesta, che sistema usi al momento?
emanueleguidetti
Città: Pistoia
Rockman84 ha scritto:Ottimo! Felice tu abbia risolto!
Sto usando questo, con "qualche" anno sulle spalle: https://www.asrock.com/nettop/intel/Vis ... x.asp?cat=
(Unica cosa che ho disponibile)
Monta componenti "mobile" :
- Mobile IntelImmagine HM55 Express chipset con un I5 (non so la generazione)
- NVIDIAImmagine GeForce GT425M Graphics,
La nvidia sono riuscita a farla andare miracolosamente a 15 khz forzando una specifica versione dei driver (390) con Batocera 41.
Ho provato con Batocera 42 e i 15 khz non funzionano più con nessuna versione dei driver....
Rockman84
Città: Mondovi
I giochi del Naomi e Naomi 2 vanno molto lenti?
emanueleguidetti
Città: Pistoia
Rockman84 ha scritto:I giochi del Naomi e Naomi 2 vanno molto lenti?
Ciao, non ho fatto prove a sufficienza...su NAOMI2 ho lanciato un titolo, andava evidentemente a scatti ed ho chiuso... ma ero contento perché almeno era partito! Immagine
Su NAOMI abbassando la risoluzione a 0,5 girano ma sono inguardabili... Immagine
Rockman84
Città: Mondovi
Lo immagino....diciamo che, essendo su CRT e andando quindi con la risoluzione nativa (aeppure in interlacciato), pensavo ti girassero.
Hai provato a cambiare le proprietà grafiche provando OpenGL, Vulkan ecc?
Oppure disabilitando eventuali effetti grafici inutili?
emanueleguidetti
Città: Pistoia
Rockman84 ha scritto:Lo immagino....diciamo che, essendo su CRT e andando quindi con la risoluzione nativa (aeppure in interlacciato), pensavo ti girassero.
Tutto disabilitato. Vulcan non compatibile con la mia scheda grafica....
Con modalità calma vedrò di trovare un hardware leggermente più decente.... magari un i5 "vero" e una bella R9 380.... Immagine
concordo sul fatto che tu debba salire di generazione e di scheda per sistemi di questo tipo
emanueleguidetti
Città: Pistoia
Gothrek ha scritto:concordo sul fatto che tu debba salire di generazione e di scheda per sistemi di questo tipo
Ciao, si cercherò di farlo adesso che ho potuto fare un pò di conoscenza con questo mondo! Immagine
principekento
Città: Veneto
Grazie Inviati: 116 volte
Grazie Ricevuti: 39 volte
Messaggio da principekento »
Rockman84 ha scritto: 20/11/2025, 18:12 Ti linko anche un paio di video guide fatte bene, seppur relative a versioni di Batocera più vecchie della tua:
Imparo
Imparo
Imparo
Imparo
Imparooo
Imparoooooo
Imparoooooooooooooooooooooooo
(by Kintato Oe) <-lol-> <-lol-> <-lol-> <-lol-> <-lol->
emanueleguidetti
Città: Pistoia
Dopo aver sostituito il PC con un i5 6600 e scheda video R9 380 anche NAOMI2 va che è una meraviglia!
ImmagineImmagine
mrforever
Città: Puglia
Grazie Inviati: 88 volte
Grazie Ricevuti: 35 volte
Messaggio da mrforever »
Mah al posto di tutto quel macello ci avrei messo una bella recalbox con raspy 5 e vedi come va! Ovviamente gira sui tubi sia 15 che 31
