Batocera 40
Batocera 40
Di seguito il changelog della versione uscita stanotte:
Special Notes
Batocera now has a global battery mode option under Game Settings to determine the power mode when a handheld is unplugged.
To potentially improve battery consumption, you can adjust the mode the handheld operates at when running on battery.
By default the power mode will be set to `balanced` mode when unplugged. Other options are `highperformance` or `powersave`
Note: The `powersave` mode will have the biggest impact on CPU performance whilst gaming to reduce battery consumption as much as possible.
Singe games now have their own system. Move any Singe related games from `roms/daphne` to the `roms/singe` directory.
Note: Singe games in the `roms/daphne` folder will no longer work.
You can determine you have a Singe simulation game when the game folder contains a .singe file.
EmulationStation's Video Mode (resolution) is now under System Settings rather than under Frontend Developers.
Hardware
Add support for the Pironman case with RPI4 devices.
Add support for OrangePi Zero 3 (all variants)
Add support for Radxa Rock 3C
Initial support for the Lenovo Legion Go
Support for Nvidia cards requiring the legacy 340.108 driver.
Add support for the Ayaneo 2S
Add support for the Ayaneo Air Plus (6800U) model
Add support for the Radxa Rock 5c
Add support for the Banana Pi BPI-M7
Add support for the Pironman 5 case with RPi5 devices.
Added
Support for Lexaloffle Voxatron (needs official engine, no emulator provided)
C64: support for REU (RAM Expansion Unit), .d71 and .g64 ROM format
Light gun support in Libretro-MAME
Light gun support in DuckStation (single light gun only)
Libretro-Flycast ES setting for offscreen reload as button 2 on the light gun
Light gun crosshairs for PCSX2, libretro-swanstation, Flycast, RPCS3, MAME (standalone) and libretro-pcsx-rearmed
Support for zedmd
DMD server (handling any dmd supported by libdmd) integrated with vpinball
Support for multi screens (for pincab, mame multi games)
Evmapy keys file to help exit running flatpak app
Steering wheel support for:
Thrustmaster T150RS
Thrustmaster T80 (gamepad mode only)
Thrustmaster Ferrari GT 2 in 1 Rumble Force Racing Wheel
Driving Wheel SV200
PNX-V10 (x-input only)
Logitech Driving Force Pro
HORI Racing Wheel Overdrive (mode 2 only)
Dolphin: support for Retroachievements
Color Computer (coco) now autoloads cassettes and disks based on MAME software lists with default fallbacks
uses "usage" info field in MAME software list
.cas/.dsk default autoload behaviors (.bas in rom basename uses CLOAD/RUN)
user overrides declarable in `system/configs/mame/autoload/coco_{cass,flop}_autoload.csv`
"Tandy Radio Shack Color Computer cassettes" softList added to coco Advanced Game Options
RetroAchievements for Flycast & Libretro-Flycast (when they are enabled)
Chihiro support via Xemu for Xbox compatible Chihiro patched games.
Bezel support for Daphne/Singe (can be toggled off)
Foot pedal for light guns on libretro cores, Duckstation, PCSX2 and MAME standalone
Bind key C for player 1; V for player 2; B for player 3; N for player 4
Nvidia cards using the latest production driver now has cuda hardware accelerated playback enabled for ffmpeg & mpv
Wireguard VPN tools to setup your PC for Wireguard VPN access. See the wiki here: https://wiki.batocera.org/vpn_client
Support for standalone MAME (MAME) and libretro-MAME (lr-mame) BIOS files in bios/mame/ subfolder
BIOS files in /userdata/bios/mame have precendence over /userdata/bios (per MAME -rompath behavior)
Start and Select buttons on light guns for Hypseus Singe
Fixed
RA menu confirm/cancel inputs now follows ES confirm/cancel setting.
RG552 Splash-screen rotation
RG552 Vibrator enabled
GameForce Vibrator enabled
Vita3k moving saves
Steam flatpak issue after forced runtime update.
GunCon2 A and B buttons now separate
Sinden Lightgun now has limited bandwidth per camera to avoid timeout
Some Kodi settings were lost upon Batocera upgrades
Wii crosshairs in the wrong emulationstation group setting
Justifier gun type in emulationstation for pcsx-rearmed and mednafen cores
Justifier mapping and crosshair on libretro-snes9x
Daphne crosshair not hidden by default when a light gun is detected
Libretro-Mesen light gun not loading up
Vulkan driver version via System Information whne using a multi-GPU systems was sometimes wrong
Fix SteamDeck LCD mono audio which snuck in with the v39 release.
ScummVM configuration file location & ensure native file system is turned off
Duckstation: faster loading time when RetroAchievements are enabled
Color Computer .dsk floppy images accepted in ES. "Disk" altRomType added in Advanced Game Options
Hypseus Singe light gun accuracy with selected ratio
Rpi4 udev rules when a gun is detected in Hypseus Singe
Scanlines not showing in Daphne/Singe
Supermodel persistent crash in some cases with light guns
Cuda hardware acceleration of the splash video for Nvidia cards using the production driver.
Kodi green screen with RK3588 boards
Changed / Improved
Organized dolphin ES settings.
Amiga BIOS files now go into the bios/amiga/ subfolder
RPCS3 upscaling now outputs properly
GunCon3 default mapping (visit light gun page on official wiki)
Calibration now on C2 (press and hold it few seconds)
Sinden Lightgun drivers updated to 2.05 (firmware v1.9 now compatible)
Preferred vulkan driver & version now listed in System Information
Improve Vulkan GPU driver handling for Emualtors
Added additional Atari Lynx extensions for Beetle Lynx & Handy
Name the Bluetooth connection based on the host system hardware name.
We now record audio & use hardware encoding (x86_64 only) with Intel & AMD GPU's when using `batocera-record`.
Recorded videos are now saved in `/recordings/` folder
Moved the RK3588 boards to the new Mesa 3D Panthor driver (now supports more emulators)
Updated
Retroarch to 1.18.0
Libretro cores for retroarch 1.17.0 [#11113](https://github.com/batocera-linux/batoc ... 1113/files)
Mupen64plus-core bump to Jan 25, 2024 build
Mupen64plus-audio-sdl bump to Jun 11, 2023 build
Mupen64plus-input-sdl bump to Nov 4, 2023 build
Mupen64plus-ui-console bump to Jun 11, 2023 build
Mupen64plus-rsp-hle bump to Jan 13, 2024 build
Mupen64plus-video-glide64mk2 bump to Jun 11, 2023 build
Mupen64plus-video-rice bump to Jun 11, 2023 build
Mupen64plus-gliden64 bump to Feb 18, 2024 build
PPSSPP: to v1.17.1
Duckstation to v0.1-6892
Libretro-PPSSPP: to v1.17.1
Libretro-81: bump to Nov 1, 2023 build
Libretro-Fbneo: bump to Feb 23, 2024 build (v1.0.0.03)
Libretro-Genesisplusgx: bump to Feb 23, 2024 build
Libretro-MAME: to 0.265
Libretro-MAME2003-plus: bump to Feb 21, 2024 build
Libretro-Mupen64plus-next: bump to Feb 6, 2024 build
Libretro-Neocd: bump to Feb 1, 2024 build
Libretro-Opera: bump to Jan 13, 2024 build
Libretro-Stella: bump to Jan 2, 2024 build
Libretro-Swanstation: bump to Jan 25, 2024 build
Libretro-PCSX: bump to Feb 14, 2024 build
Libretro-Flycast: bump to v2.3.2
Redream to 1.5.0-1127-g6b62eff
Ikemen Go to May 17, 2024 build
Amiberry to 5.6.8
GroovyMAME to 0.265 SR 0.220c
DOSBox-Staging to 0.81.1
DOSBox-X to 2024.03.01
SimCoupe to 1.2.13
Tsugaru to 20240223
Fallout 1 CE to v1.1.0 (March 2024 release)
DevilutionX to 1.5.2
Commander Genius to 3.5.0
Kodi to 20.5-Nexus
RPCS3 to 0.0.32-16618
Solarus-engine: bump to Apr 27, 2024 build
Cemu to v2.0-82
Sonic3-AIR to v24.02.02.0-stable
Ruffle to 2024-03-28
Xenia Canary to build 5bbba85 (Commits on May 14, 2024)
Xemu to v0.7.121
ScummVM to 2.8.1
Fheroes2 to 1.0.13
PCSX2 to v1.7.5913
Play! & Libretro Play! to 0.66
Dolphin to 2407-76 (5.0 development version)
Libretro-Hatarib: bump to v0.3
Hatari to v2.5.0
Citra to r64e3e9f
ETLegacy to v2.82.1
GZDoom to v4.12.2
Fallout2-CE to v1.3.0
Raze to v1.10.2
Vice to v3.8
The Force Engine to Apr 29, 2024 build (Supports HD Textures)
DXX-Rebirth to May 6, 2024 build
BigPemu to v113 (Linux Build)
Xenia to v1.0.2815
Vita3K to June 5, 2024 build
Sonic-Mania to Mar 7, 2024 build
Libretro-Cap32 to May 15, 2024 build
Libretro-Arduous to May 14, 2024 build
Libretro-Beetle-PCE to May 3, 2024 build
Libretro-Beetle-PCE-Fast to May 10, 2024 build
Eduke32 to May 14, 2024 build
Hurrican to Dec 27, 2023 build
Sonic Mania to May 10, 2024 build
VCMI to v1.5.1
Xash3d-fwgs to May 15, 2024 build
AppleWin to May 12, 2024 build
MelonDS to May 16, 2024 build
Snes9x to May 14, 2024 build
TheXTech to v1.3.6.5
Libretro-WASM4 to v2.7.0
Libretro-Tic80 to May 16, 2024 build
Libretro-Chailove to May 18, 2024 build
Libretro-Fake08 to Apr 17, 2024 build
Libretro-Freechaf to Apr 26, 2024 build
Libretro-MiniVMac to Apr 26, 2024 build
Libretro-MrBoom to May 17, 2024 build
Libretro-Picodrive to Mar 27, 2024 build
System
ARM mainline kernel to 6.6.27
Nvidia Production driver to 550.90.07
Nvidia Legacy driver to 470.239.06
Wayland Protocols to 1.33
Wlroots to 0.17.1
Sway to 1.9
Mesa3D to 24.1.4
RPi kernel to 6.6.41
Pipewire to 1.0.4
X86_64 kernel to 6.9.10
Switchres 0.220
Btop to 1.3.2
Linux firmware to 20240513
Buildroot to 2024.02.1
Xpad-Noone to Jan 10, 2024
XpadNeo to Apr 23, 2024 build
Xone to Mar 30, 2024
Fdupes to 2.3.0
FAudio to 24.05
Sound Open Firmware to 2024.03
RyzenAdj to v0.15.0
QT to 6.7.0
DXVK to 2.3.1
DXVK-NVAPI to 0.7.0
VKD3D-Proton to v2.12
Vulkan headers to 1.3.286
Bluez to 5.76
Domino
Città: Salagiochi
Grazie Inviati: 26 volte
Grazie Ricevuti: 7 volte
Re: Batocera 40
Messaggio da Domino »
speriamo nello script 15khz per crt
Rockman84
Città: Mondovi
Grazie Inviati: 143 volte
Grazie Ricevuti: 110 volte
Re: Batocera 40
Messaggio da Rockman84 »
Esatto.
Re: Batocera 40
ci sono alcune cosette interessanti,
la prima la svalangata di volanti e light gun che mano mano stanno integrando,
l'altra la gestione separata dei singe dal daphne
va tenuto conto e spiegato magari a chi ne sa meno, che in ogni versione di bato, vengono aggiornati i driver grafici in generale e nvidia in particolare, pertanto nuove versioni portano con se nuove esclusioni soprattutot per pc piu' datati
Re: Batocera 40
è tornato Gothrek!
Re: Batocera 40
DigDug ha scritto: 12/08/2024, 9:19 è tornato Gothrek!
mesi complicato con trasloco e lavori a casa, sto cewrcando di riprendere :D
meno male che c'eravate voi :D
Rockman84
Città: Mondovi
Re: Batocera 40
Bentornato amico <-preved->
jahpohke
Città: Varese
Grazie Inviati: 59 volte
Grazie Ricevuti: 88 volte
Re: Batocera 40
Messaggio da jahpohke »
chissà se coi driver nuovi l'AMD che ho sul PC in appartamento con una MSI A620 per Ryzen inizierà a non fare più artefatti a 50hz e soprattutto....cosa assurda, non necessaria visto che non vado oltre neogeo, e al contrario di ogni normale logica, riuscirà a farmi anche l'interlacciato. Riuscire ad avere i 50hz puliti per qualche gioco commodore non sarebbe male comunque
E' notte Ted...
Rockman84
Città: Mondovi
Re: Batocera 40
Qui un video riepilogativo in italiano sul "changelog" di Batocera 40
https://youtu.be/AschA4ap0Ck?si=pGDfcghFdE5jCSEM
