Sfida in corso: BOMB JACK
Area dedicata alla parte videoludica.
Sfide e approfondimenti sui nostri amati Videogames.
Classifica dei punteggi migliori
Si parte con la sfida votata per dicembre/gennaio:
BOMB JACK
http://adb.arcadeitalia.net/dettaglio_m ... e=bombjack
alcune info recuperate da ADB:
PUNTEGGIO
Jumping, hitting a wall or falling from a platform: 10 points x bonus multiplier value.
Normal bomb: 100 points x bonus multiplier value.
Firebomb: 200 points x bonus multiplier value.
(P) Power: 100 when blue, 200 when red, 300 when purple, 500 when green, 800 when cyan, 1,200 when yellow and 2,000 points when grey x bonus multiplier value.
(B) Bonus Multiplier: 1,000 points x bonus multiplier value.
(E) Extra Life: 1,000 points x bonus multiplier value plus an extra life.
(S) Special: 1,000 points x bonus multiplier value plus a free credit.
Killing monsters while (P) is active: 100, 200, 300, 500, 800, 1,200 and 2,000 points. These are all multiplied by the current bonus multiplier value.
End of level bonus:
23 firebombs defused: 50,000 points.
22 firebombs: 30,000 points.
21 firebombs: 20,000 points.
20 firebombs: 10,000 points.
CONSIGLI E TRUCCHI
A little information about the appearance of the powerball: the rule is very simple and you just have to look at the colour at the left and right of the multiplicator number, its size grows as you collect bombs.
1) Take a 'lit bomb' and you get 1 point ahead for the next Powerball. Take a non-lit bomb and you'll get 0.5 point for the next Powerball. When you achieve 10 points, the powerball appears. Your powerball points don't grow if either the powerball is there or if the 'power music' is playing, so avoid collecting bombs when it's not necessary.
2) The powerball can have different score values when taking it. When it appears, jump or hit a wall and its colour will change. The colours and score values are blue (100 points), red (200 points), purple (300 points), green (500 points), turquoize (800 points), yellow (1000 points) and grey (2000 points).
3) The 'B' bonus coin adds 1 to the multiplicator value and appears each 5,000 points, but only if you 'pass' these 5,000 points when not taking a 'B' coin. For example, your multiplicator is 2x, your score is 9,000 and you take a 'B' coin; giving you 1,000x2 = 2,000 points which makes a total of 11,000 points. A 'B' coin should then appear because you have passed the 10,000 points, but doesn't because you took a 'B' coin to achieve this score so you'll have to wait for 15,000 points to get a new 'B' coin. The multiplicator limit is X5.
An important piece of information to remember is that you can pick up the bombs in a certain order to earn maximum points. If you pick up most of the bombs while their fuses are lit, you get the following bonuses:
20 - 10,000 pts.
21 - 20,000 pts.
22 - 30,000 pts.
23 - 50,000 pts.
So of course, you'll want to try to get 23 each time (This is of course, VERY difficult!). The P (Power) coin appears after every ninth bomb is collected. The points value of the P coin ranges from 100 (Blue) to 2,000 (Silver). Since the color changes each time BJ jumps, you can control the bonus level by making small jumps until the coin turns silver.
The B (Bonus) coin appears every 5,000 points, and advances the bonus multiplier by 1. There is a maximum of 5 B coins per level.
Picking up the S (Special) coin awards one free credit. It will also take you to the next level automatically.
You can control where the mechanical bird appears by holding the joystick in the opposite direction. Example: Hold the joystick to the Right as soon as the round starts and the mechanical bird appears on the left of the screen. If the stick is held diagonally, the bird appears in the opposite corner.
When you start a level, and directly go to left or right, bird(s) will appear on the other side: it's useful to put them where you want in order to make this level easier, levels 7, 8 & 9 are good examples for that.
MAMESCORE records: 26/12/2018 17:47
kernzy.....................73.378.560
genekelly...................4.000.000
sawys.......................1.152.520
bipbip......................1.076.750
warlike.......................970.950
olivier.......................733.620
nicky634......................573.210
cessna........................544.510
dark.kariya...................304.910
ezequiel......................269.710
pluon22.......................267.430
muesliman.....................265.990
lamangouste...................204.350
ballyballo....................179.180
starfab.......................165.500
foxmulder.....................158.360
didyeah.......................107.440
fly.saya.......................68.840
vikleroy.......................51.460
zarouk.........................49.680
jgabmurer......................40.380
hulkiii........................19.270
mode: summer
gohat0........................489.440
largolgd......................477.970
lorddraakh....................428.060
nicky634......................399.580
hulkiii........................13.470
qui un video:
https://www.youtube.com/watch?v=NF_Gmc2LT2s
buon divertimento.
CLASSIFICA ARCADE ITALIA:
1) 944.090 - @elmet 18/01/2024
2) 691.700 - @larasa 18/01/2024
3) 643.700 - @Vinylmen 18/01/2024
4) 339.410 - @segarally 09/01/2024
5) 18.870 - @Gothrek 31/12/2023
Grazie Ricevuti: 161 volte
Re: Sfida in corso: BOMB JACK
partiamo da qua ...
lo so dico un'eresia ma questo gioco non lo sopportavo neanche ai suoi tempi, lascio il mio record hahaha
Rockman84
Città: Mondovi
Grazie Inviati: 143 volte
Grazie Ricevuti: 110 volte
Messaggio da Rockman84 »
Grande Giove!
@larasa la tocca piano e stacca subito un punteggio extra-terrestre.
E la frase sibillina "partiamo da qua" non mi lascia per nulla tranquillo <-clap->
... ai tempi, 85-86, mi ricordo che il milllione l'avevo raggiunto un paio di volte ...
poi ... la seconda rom, set2, è leggermente piu facile, con lo stesso dip switch.
É ovvio che per fare punti bisogna prendere i bonus da 50mila, imparare a memoria come si accendono le "bomb" e sfruttare i x2 x3 x4 x5 che escono ogni 5000 punti, ogni tanto dà una "E", 1 vita, e raramente la "S", 1 partita.
Ultima modifica di larasa il 05/01/2024, 10:46, modificato 1 volta in totale.
nicoweecade
Città: BS
Grazie Inviati: 33 volte
Grazie Ricevuti: 21 volte
Messaggio da nicoweecade »
larasa ha scritto: 31/12/2023, 13:57 partiamo da qua ...
per me è fantascienza, non ci provo nemmeno!
buon divertimento :-D
segarally
Medaglie: 8
Messaggio da segarally »
Dopo un paio di partite fatte al volo non capisco se:
  • A: sono veramente vecchio da non ricordarmi più come si gioca ad un "classico" come Bomb Jack !!!
  • B: è tutta colpa del cab portatile dotato di scheda "cinese" Zerodelay !!!
  • C: non mi interessa, non compro niente, vado di fretta...
proverò sul cab...anche se ho paura che la risposta giusta sia la "A"...
vedo risultati incoraggianti, ma quello che mi preoccupa è il silenzio di vinylmen, comunque in 6 hanno scelto bomb jack e almeno 6 risultati vorrei vedere, dai dai dai !
per renderla un po piu difficilina ... se prendete la P argentata farete un po piu punti, il colore della P cambia ogni volta che jack tocca qualcosa ...
Ultima modifica di larasa il 06/01/2024, 11:24, modificato 1 volta in totale.
elmet
Città: Catania
Grazie Inviati: 5 volte
Grazie Ricevuti: 36 volte
Messaggio da elmet »
Qui il mio..
elmet
Città: Catania
Partitina di stamattina
Apperò
segarally
Medaglie: 8
Complimenti !!!
puttanis...
classifica aggiornata.
Vinylmen
Città: Fabbrico
Messaggio da Vinylmen »
Il mio silenzio è dovuto alla vacanza in portogallo che mi sono concesso con amici,dalla quale sono rientrato oggi (Lisbona.. 28/12--08/01 ) Mi riposo e prox giorni vedo un pò.... ;-) Vinyl....
segarally
Medaglie: 8
Un po di svago, leggermente off topic, tra una partita e l'altra ... forse qualcuno riconoscerà qualcosa ...
... dal megafono della motonave :" Oggi abbiamo visto i delfini ! " ....
A me ricorda Cesenatico ...
elmet
Città: Catania
Cabinati diversi ,livelli più alti ma punteggio no
schiaffi alla povertà...
zergatto
Città: prato
Messaggio da zergatto »
io questo lo passo...lo odiavo da ragazzo e non i ci rimetto sicuramente adesso!!! buona sfida a tutti!!! p.s. intanto provo a migliorarmi su sonson e mappy!!!!
zergatto ha scritto: 13/01/2024, 20:02 io questo lo passo...lo odiavo da ragazzo e non i ci rimetto sicuramente adesso!!! buona sfida a tutti!!! p.s. intanto provo a migliorarmi su sonson e mappy!!!!
daje addosso e pubblica i record nei rispettivi topic
Torna a “Top Score”
