Batocera 36
Batocera 36
Con un giorno d'anticipo è stata rilasciata la versione 36.
Di seguito il changelog:
EmulationStation
volume for libretro cores can be changed per-game from es, may be extended to other emulators in future
brightness can go down to 1% (instead of 5%)
holding power button 3s will show the shutdown menu
new enhanced UI for themes management (from Content Downloader)
navigation with light guns now possible
Added
Support for RK3328 Rock64(Pine64) & Roc-cc(firefly) Boards
added odroid-n2l support
alsa ucm2 to x86 builds for soundcard compatibility - v1.2.8
sound open firmware for expanded soundcard support - v2.2.3
- manual config is necessary
Vita3k - PlayStation Vita emulator (Nov 28th build)
WASM4 - WebAssembly fantasy console (x86_64)
Ikemen-Go fighting engine (x86_64)
automatic switch when a new display is plugged or unplugged (on es only for plugging)
Intel VAAPI drivers for hardware video playback acceleration
Light gun in-game pre-calibration for arcade (atomiswave, naomi, MAME, lr-mame, lr-mame2003-plus, model2, model3) and Wii
Mesa hadware codecs for supported Intel & AMD cards
Zink for OpenGL to Vulkan (advanced script use only)
patch to allow Switch clone controllers to work in some cases
patch to allow Sony Playstation clone controllers to work in some cases
Xenia a Microsoft Xbox 360 emulator (v1.0.2775) - requires x86_64+Vulkan card & Wine (Note: Limited compatibility)
- xenia-canary release is also included - build at f55defc
- Xbox 360 digital titles can now be seen via .xbox360 playlists in ES
Light gun support for Wii (up to 4 players)
Light gun support for PS3 (up to 2 players)
initial Intel A770 GPU support
Enabled libretro-yabasanshiro for platform RK3399
force feedback for Nintendo controllers (requires linux kernel 5.16 or later)
Added wayland + sway support for single board computer (SBC)
Automatically recenter 16:9 bezels for a better rendition on 16:10 and 5:3 screens (SteamDeck and other handheld devices)
Added the initial Radxa RockPi 5b board support - thanks @stvhay for your persistence & hard work!
Retroachievements for Arduboy and WASM4
Added RPI2, RPI3_32Bits and RPIZero2 support in bcm2836 image
Expanded RTW89 linux driver for Realtek 8852xx devices
Changed
Move to pipewire wireplumber audio
Bluetooth modes : automatic and manual (via a list)
Kronos now uses beetle's save path by default, move the save files out of saves/saturn/kronos to saves/saturn and rename:
- *.ram to *.bkr
- *-ext512K.ram to *.bcr
- You can continue to use the old save format by entering the following line into batocera.conf: saturn.kronos_use_beetle_saves = disabled
Cemu to native linux version (v2.0-22)
- cemu fixes for controllers
New Apple 2 MAME options - joystick & alternate models, (LR-MAME & Standalone), hard drive images (Standalone)
Playstation DS4 controllers now use the hid-playstation driver
Moving some SBC's to the Wayland display server protocol - v1.29
- Using Sway as the Wayland compositor - v1.7
- RPi4 will also use XWayaland - v22.1.7
- Removed 'redream' emulator which fails under wayland
Light gun support for GUN4IR (was partial in v35)
RG552 updated to kernel 6.1 (Thanks Maccraft123 and brooksytech)
RG552 adding mesa3d and wayland support
General tweaks for the Sinden Lightgun
- Default camera settings changed to recommended : exposure to -7; brightness to 120; contrast to 60
- Border mode : auto is NORMAL (always shown); IN-GAME ONLY; HIDDEN (always off)
- Border frame : auto is now MEDIUM with a thicker line; THIN and MEDIUM don't have outerframe anymore; BIG has outerframe
- Recoil : DISABLE option added
Updated
pcsx2 to v1.7.3292
alsa to 1.2.8
ruffle to August 19th release
lightspark to August 18th release
btop to 1.2.8
ryzenadj to 0.11.1
pipewire to 0.3.63
rust to 1.63
bluez to 5.66
xemu to 0.7.67
citra to nightly-1784
dolphin to 5.0-17316
rpcs3 to v0.0.25
flycast emulators to Jan 14, 2023 build
dosbox to v0.78.1
dosbox-x to v0.84.3
dosbox-staging to v0.79.1
PPSSPP & lr-PPSSPP to v1.14
nvidia production driver to 525.60.11
nvidia legacy driver to 470.161.03
nvidia legacy 390 driver to 390.157
openMSX to v18
moonlight embedded to v2.5.2
groovy mame to 0.247
hatari to v2.4.1
fsuae to July 30 build
scummvm to v2.6.1
simcoupe to v1.2.11
supermodel to Nov 14, 2022 build
tsugaru to v20220702
vice to 3.6.1
linux kernel for x86_64 to 6.1 lts
daphne emulator hypseus-singe to v2.10.1 (now uses SDL controller)
amiberry to v5.4
mame to v0.251
switchres to sep 25th 2022 build
lr-mame to v0.251
retroarch to v1.14.0
libretro cores update
libretro-core-info to Oct 04 2022 build
retroarch-assets to Oct 24 2022 build
common-shaders to Apr 16 2022 build
glsl-shaders to Sep 23 2022 build
alllinuxfirmwares to 20221214
mupen64plus-video-rice to Sep 30, 2022
mupen64plus-video-glide64mk2 to Nov 17, 2022
mupen64plus-ui-console to Oct 01, 2022
mupen64plus-rsp-hle to Sep 30, 2022
mupen64plus-input-sdl to Sep 30, 2022
mupen64plus-audio-sdl to Nov 30, 2022
mupen64plus-core to Dec 3, 2022
moonlight embedded to 2.5.3
wine-proton to 7.0-5
vkd3d-proton to v2.8
vulkan stack to v1.3.231
lr-yabasanshiro to 28th sept build
lr-flycast emulators to Jan 14, 2023 build
bezels updated for many systems
xpandneo to v0.9.5
Fixed
lr-mame save state file names
slow rpcs3 initial ppu compilation times
rpcs3 cache & saves dir
- note: move existing cache from /userdata/saves/rpcs3 to /userdata/system/cache/rpcs3
can now boot in verbose mode from syslinux (spam down on keyboard while booting)
moonlight embedded not connecting to streams
mesa vaapi for additional cards
long start times with vulkan in some cases
Sony touchpad for Mame
od-commander fixed for several screen resolutions
disabling rumble for some libretro emulators/controllers
Xbox S|X controllers with the RPi4
White frame on 4:3 screen in libretro cores for Sinden Lightgun
Future Pinball saves
Light guns on RPi4 - they now start when connected/plugged
Dev
buildroot upgrade to 2022.11.1
odroidxu4 upgrade kernel to 6.1.10
raspberrypi upgrade kernel to 6.1.8
Amlogic upgrade kernel to 6.1.9
rpi1 image renamed to bcm2835
rpi2 image renamed to bcm2836
rpi3 image renamed to bcm2837
rpi4 image renamed to bcm2711
ffmpeg updated to 5.1.2
libva updated to 2.16
rtl8192eu update to Nov 5, 2022
rtl8723ds update to Nov 4, 2022
rtl8812au update to Nov 16, 2022
mesa3d update to 22.3.5
uinput-joystick update to Feb 11, 2022
firmware-orangepi update to Jan 13, 2023
The build of RG552 has been added to RK3399
firmware-wlan-aml update to Jan 15, 2022
Wayland version 1.21.0
Wlroots version 0.16.1
Sway version 1.8
EmulationStation
Added
Changed
- *.ram to *.bkr
Updated
pcsx2 to v1.7.3292
alsa to 1.2.8
btop to 1.2.8
ryzenadj to 0.11.1
pipewire to 0.3.63
rust to 1.63
bluez to 5.66
xemu to 0.7.67
rpcs3 to v0.0.25
dosbox to v0.78.1
dosbox-x to v0.84.3
openMSX to v18
hatari to v2.4.1
scummvm to v2.6.1
simcoupe to v1.2.11
vice to 3.6.1
amiberry to v5.4
mame to v0.251
lr-mame to v0.251
xpandneo to v0.9.5
Fixed
Dev
Sway version 1.8
- Minamoto Kobayashi
- Banned
- Città: PADOVA
- Grazie Inviati: 5 volte
Re: Batocera 36
Benissimo, sto aggiornando dal mio bartop, vediamo che succede.
Speriamo non saltino fuori pasticci come solitamente accade con le upgrades di Windows ...
Quindi ora potrei caricare direttamente le ROMs del MAME .252 scremato (senza giochi non funzionanti) senza problemi, giusto?
- Banned
- Città: PADOVA
Re: Batocera 36
Ok funziona tutto a dovere .. ma sono spariti tutti i dati di scraping .. bisogna rifarlo?
Una cosa non ho capito ... quale sarebbe il POWER BUTTON?
Re: Batocera 36
i media dati dovrebbero essere ancora dentro le cartelle delle roms (puoi verificarlo da un pc windows collegato alla rete (o da f1 di batocera) entrando in share roms mame al cui interno deve essereci la cartella media (con i vari media dentro divisi eventualmente in sottocartelle), nella cartella delle roms, deve essre il file gameslist.xml che è quello che viene usato da batocera e da altri frontend, per associare i media e i metadati alle roms.Minamoto Kobayashi ha scritto: ↑09/03/2023, 23:55 Ok funziona tutto a dovere .. ma sono spariti tutti i dati di scraping .. bisogna rifarlo?
Re: Batocera 36
c'è la possibilità di installare la nuova versione facendole 'digerire' la partizione preesistente delle rom ? Oppure durante l'installazione crea comunque la seconda partizione cancellando tutto ?
Re: Batocera 36
non so se ho capito bene la domanda.
Se stai aggiornando lui prende in carico la partizione già configurata, se è una nuova installazione nel processo con balena etcher lui formatta e partiziona tutto.
Se le rom sono su unità esterna (in gnerale lo sconsiglio), lui non tocca nulla, nella nuova isntallazione gli va detto dove sono.
Detto questo mi chiedo perchè? potresti reinstallare/installare e copiare le rom nelle dovute cartelle
Re: Batocera 36
Forse mi sono spiegato male; la mia intenzione è quella di installare (non aggiornare) alla versione 36, mantenendo però intatta la partizione delle rom/salvataggi.
Non potreti farlo se non perdendo più di mezza giornata
Grazie per la conferma.
- paginetto
- Città: Biella
- Grazie Inviati: 13 volte
- Grazie Ricevuti: 4 volte
Re: Batocera 36
Aiuto! Mi sono già pentito di aver aggiornato al 36.un sacco di problemi mai avuti. Il model3 ho dovuto rifare il file di testo gamelist con le modifiche sennò non partiva più nulla, su Saturn un emulatore è diventato molto lento ,atomis wave mille ricerche per trovare poi un Tizio che ha risolto con una modifica nelle decorazioni sennò non ne partiva più neanche uno.adesso scopro che Mario kart 8 per Wiiu non mi parte più,ed era perfetto prima.formato rpx . C'è qualche trucco anche qui x caso?
Pazzo x batocera
- Banned
- Città: PADOVA
Re: Batocera 36
Ciao.
Mi rendo conto che ogni volta che si fa un aggiornamento salta fuori un problema strano.
E non e' sempre lo stesso bug, ne sto sentendo di tutti i colori.
Guarda me ad esempio: la prima volta che ho aggiornato non mi partiva piu' nemmeno un gioco.
Fortunatamente prima di fare un qualsiasi aggiornamento clono sempre l'hard disk originale su un altro HD con il programma Balena Etcher,
cosi' se qualcosa va storto ripristino facilmente l' installazione precedente.
Ebbene ci ho riprovato, ho riapplicato l' aggiornamento sopra la versione v35, e' sparito il problema dei giochi che non partivano, ma ora ne ho un altro,
fortunatamente meno grave del precedente: ogni tanto il sistema decide in autonomia di ignorare le mie configurazioni e moddature
(e ne ho fatte veramente tante) e parte come se fosse stato installato ex novo, nudo e crudo di default.
Riavvio, e le mie configurazioni riappaiono per incanto. Per poi, dopo qualche riavvio, scomparire di nuovo.
Gotrek mi ha consigliato di non aggiornare mai, ma di installare sempre tutto ex novo, ma cosi' facendo perderei tantissime
configurazioni, cosi' ho chiesto aiuto su Discord.
La prima cosa che mi hanno detto, se avessi avuto bisogno di un loro aiuto, e' di cercare due LOG files (che ora non ricordo quali siano
e dove trovarli) dove il sistema registra tutti gli eventi (ed i probabili errori) durante la fase di boot e di postarli sul forum apposito,
in modo tale che possano esaminarli per trovare una possibile soluzione.
In fin dei conti noi siamo involontariamente dei beta tester, ed ogni segnalazione di malfunzionamento puo' tornare utile a tutta
la comunita' per applicare eventuali patches nelle release successive di Batocera.
- paginetto
- Città: Biella
Re: Batocera 36
Ok però ci sono state versioni beta x mesi.quando esce quella stabile non ci si aspetta così tanti problemi.adesso c'è già la beta della 37 che risolve ad esempio quel problema su saturn e altro.diventa un dilemma.aggiorni risolvi una cosa,ma di certo non ne funzionerà un'altra.ora pensavo a come tornare alla versione di cemu per Wiiu sul 36 , ma senza toccare tutto il resto.andando a tentativi,tipo da dentro retro arch da applicazioni ,gestione dei core.non so se è giusto.improvviso.o viceversa aggiornare solo cemu alla versione che c'è nel 37.chissà.
Pazzo x batocera
Re: Batocera 36
consiglio in generale difronte a qualunque aggiornamento di qualunque sistema operativo un processo tale per cui:
1) aggiorno solo se ne ho bisogno
2) installare su altro hd, provare
3) tenere un backup
nello specifico per batocera, io faccio cosi:
1) prendo altro hdd ed installo da zero la nuova versione (tra i 3 e i 5 min)
2) prendo un po di rom dei vari sistemi che ho sulla vecchia versione e li provo sulla nuova (tempo della copia anche qui pochi min)
3) se tutto va prendo rom e configurazione e li metto sul nuovo cosi da tenere la vecchia versione pronta (le cartelle sono 2 da copiare lo faccio da un pc windows in rete, tempo anche qui prossimo ai 2 min)
quando uscira la nuova versione potrò riciclare l'hdd vecchio e cosi via
in tutto questo processo i minuti persi sono pochissimi, ho sempre la possibilità di tornare indietro e mi lascia il massimo dell'autonomia.
3) tenere un backup
- paginetto
- Città: Biella
Re: Batocera 36
Ottima tattica Ma io essendo meno esperto ci metterei invece un sacco di tempo per quelle fasi Anche perché gestire 80 diversi sistemi Quindi circa 200 emulatori ogni volta da provare per 80.000 Rom diventa impegnativo, perciò la mia tattica è quella di avere una chiavetta da 64 GB dove faccio tutti gli esperimenti e ci tengo solo ciò che tengo solo le cose principali e quando mi sembra che tutto funzioni faccia l'upgrade sull'hard disk principale dove tengo tutto, solo che questa volta mi sono fidato un po' troppo in anticipo e adesso sto notando una marea di differenze rispetto a prima e anche molte personalizzazioni e configurazioni che avevo fatto che sono tornate al default e le sto cercando di rimettere a posto. Poi con batocera Mi capitano un miliardo di cose stranissime ad esempio oggi mi accorgo che nel sistema vectrex in tutti i giochi la direzione su e giù del controllo è invertita e nemmeno mappando dentro al core i comandi al contrario cambia qualcosa, cose davvero stranissime. Tuttavia adesso mi resta il mistero della Wii U emulata da cemu che è passata dalla versione 1.26 dove funzionava tutto alla versione 2.0 sperimentale dove Super Mario 3D World va benissimo Mentre Mario Kart8 si rifiuta proprio di caricarlo e non saprei proprio capire il motivo.
Comunque il sega model 3 dove bisogna editare il file di testo altrimenti molti titoli non partono seguendo una guida trovata su batocera Nation e il sistema triforce sono i due che mi hanno fatto impazzire di più in questi mesi soprattutto per settare i controlli
Pazzo x batocera
- Banned
- Città: PADOVA
Re: Batocera 36
Ed io che pensavo che fossero solo gli aggiornamenti Windows a creare problemi .. a quanto pare anche Linux e' "umano" ..
- principekento
- Città: Veneto
- Grazie Inviati: 119 volte
- Grazie Ricevuti: 39 volte
Re: Batocera 36
Ma perche' aggiornate a oltranza? Se il sistema e' stabile non conviene lasciarlo cosi' com'e'?
- paginetto
- Città: Biella
Re: Batocera 36
Beh il mio primo batocera è stato il 35 , non avevo mai provato.sono andato sulla fiducia ignorando le versioni beta.ora me le ricorderò.aggiorno solo se necessario.hanno comunque aggiunto nuovi sistemi nell'ultima versione come la ps vita , poi speri sempre che i nuovi core aggiungano velocità e compatibilità o nuove funzioni.o che magari quel poco che non funzionava sia stato risolto.invece siccome c'è molta personalizzazione già fatta è più il danno del beneficio.starò più attento.chiavetta piccola già messo il 37 x le prove.hard disk grande non lo aggiorno più e ottimizzo.
Pazzo x batocera
