Batocera 5.27 appena rilasciato
Mentre recalbox purtroppo arranca sulle release, portandole ad 1 l'anno e averla annunciata per inizio ottobre, batocera senza annunci anticipati rilascia nuova release (aggiornabile direttamente dalla piattaforma precedente se colelgata ad internet)
Di seguito le maggiori info nel changelog:
Batocera 5.27 - 2020/09/15
add: Retroflag NESPi 4 case support
add: wifi hidden SSID support
add: Khadas VIM3 support (see https://wiki.batocera.org/devices#khadas_vim3 for details)
add: Allwinner h5 support (Tritium-H5) from Librecomputer
add: odroid n2+ support (including overclocking up to 2400 and fan)
add: libretro-quasi88 (NEC PC-8800)
add: cannonball (outrun engine)
add: libretro-scummvm core (working)
add: batocera-record (on x86*) to record video of batocera from command line
add: filesystem compression (btrfs option in batocera.conf)
add: game manuals scrapping / rendering
add: batocera manual
add: Batocera content downloader (with 'pacman' package manager)
add: New UI for installing/removing themes, bezels, free content
add: new options for upscaling when emulators support it (PSX, Dreamcast, DS, Gamecube, Wii...)
add: system manufacturers bar
add: flags for games locales
add: support for RTL languages (arabic translation)
add: multi-thread support for ScreenScraper
add: oc_FR language
add: Vulkan support
add: technical stats and info on SSH login
add: resolution configuration by system/game for many boards
add: rpi4 saturn support
add: n2 gamecube support
add: new batocera-splash modes (see batocera.conf)
fix: theBezelProject default bezel now correctly installed
fix: audio in video snaps (rockpro64)
fix: volume slider in ES (rockpro64)
fix: bezels resizing for ultrawide screens
fix: wifi connection
fix: RetroAchievements window (data scraping, fix for small screens)
fix: remove .zip support for CD-based systems
fix: odroid n2 owners should reburn completly the image to get better performances (overclocking)
bump: Intel Iris driver
bump: RPi3 and RPi4 kms video driver
bump: RetroArch 1.9.0 along with libretro emulators
bump: Yabasanshiro to 3.4.2
bump: PPSSPP to 1.10.3
bump: Dolphin to 5.0-12257
bump: MAME to 0.223
bump: linapple
bump: citra-emu
bump: Kodi 18.8
bump: nvidia-driver (450.66)
snuntz
Città: Fermo
Re: Batocera 5.27 appena rilasciato
Messaggio da snuntz »
Qualcuno lo ha già provato?
A me dopo il logo iniziale scompare il video e non riesco più a visualizzare nulla ne a 15Khz ne su lcd
a me tutto ok,con rpi3b+ ,LCD e tutte le impostazioni lasciate di default.
i oprovato appena uscito, aggiornato dalla 5.26 tutto bene. Ho visto tante opzioni per i bezel e chiedo a @larasa se ha trovato maggiori scelte/opzioni per il tuo problema.
Lato bios ho visto che li ha riconosciuti tutti tranne il nec-pc88xx
Audio/video tutto ok
Gothrek ha scritto: 21/09/2020, 8:35 Ho visto tante opzioni per i bezel e chiedo a @larasa se ha trovato maggiori scelte/opzioni per il tuo problema
non ho trovato niente che mi aiuti nei bezel,ma non so se le ho provate tutte,sono alle prime armi,sono seriamente orientato ad un monitor 16:9 da 10 pollici.
un piccolo difetto nell'aggiornamento forse c'é: solo nel video iniziale il volume,a me, resta sempre alto,ho provato a mettere i volumi a 50 ma quando riavvio,di notte,sveglio tutti.
larasa ha scritto: 22/09/2020, 15:59
ho visto una demo, dove (a parte modificare lo splash screen iniziale), potevi scaricare (gratuitamente) art, da una specie di store e c'erano diverse bezel già fatti.
Devo trovare il tempo per provare questa nuova funzionalità,ma con la nuova bimba in arrivo tempo libero prossimo a 0 (zero)
purtroppo non riesco a diminuire il volume dello splash iniziale,quindi indietreggio alla versione 5.26, mi spiace solo perdere il manuale dei pulsanti,vedremo il dafarsi in futuro,cambio idea spesso.
larasa ha scritto: 23/09/2020, 13:15 purtroppo non riesco a diminuire il volume dello splash iniziale,quindi indietreggio alla versione 5.26, mi spiace solo perdere il manuale dei pulsanti,vedremo il dafarsi in futuro,cambio idea spesso.
non riesco ad essere certo, ma appena riesco te lo guardo
@larasa
uscito batocera 5.27.2 bug fix, magari hanno sistemato quello che non andava
ho smontato il minibartop per montare lcd 10" 16:9 hdmi , fare il buco per la IEC320 e devo finire il coprimonitor(bezel) poi rimonto tutto e provo.
nicoweecade
Città: BS
Grazie Inviati: 33 volte
Grazie Ricevuti: 21 volte
Messaggio da nicoweecade »
chiedo pure io alcune info,
ho provato a fare una istallazione su questop mi vecchio pc assemblatio:
genuin Intell, Pentium 3 a 32 bit con 173 Mb di RAm e scheda grafica Ati Rage 128 Agl Agp.
windows 98...
HD da 40 giga
dopo mille peripezie sono riuscito a fergli leggere l'usb all'avvio (con Plop)
ma inserita l'usb con l'immagine di batocera generata con Rufus , dopo un resizing partition iniziale rimame lo schermo nero con il cursore che lampeggia in alto a sinistra e stop....
bho...
ho provato anche una versione più datata di batocera, almeno è uscita una scritta iniziale di copyright poi tutto nero e bloccato con usb che continua a lampeggiare
Ultima modifica di nicoweecade il 30/10/2020, 20:09, modificato 1 volta in totale.
rauzer
Città: Udine
Grazie Inviati: 7 volte
Grazie Ricevuti: 13 volte
Messaggio da rauzer »
Gothrek ha scritto: 15/10/2020, 21:18 @larasa
su PI4 alcuni CHD su Dreamcast non vanno. meglio restare alla 5.27 in attesa della 5.28
rauzer ha scritto: 30/10/2020, 13:59
su quali hai avuto problemi?
rauzer
Città: Udine
ho letto di molti che dopo l'upgrade alla 5.27.2 si è rotto il meccanismo di loading chd - in effetti sull'ultimo changelog di prossima uscita c'è "* fix: CHD broken support on most systems"
roberone
Città: Livorno
Grazie Inviati: 8 volte
Grazie Ricevuti: 7 volte
Messaggio da roberone »
Salve, ho installato la 5.27.2. E' la prima volta che la provo (sono utilizzatore di retropie).
Non so se sono io che non eseguo le operazioni corrette, ma ho trovato dei problemi sul salvataggio delle configurazioni.
Non riesco a memorizzare le impostazioni dei tasti.
roberone ha scritto: 20/11/2020, 11:21 Salve, ho installato la 5.27.2. E' la prima volta che la provo (sono utilizzatore di retropie).
Non ho mai riscontrato questa anomalia, anche io sto unsado nel cab la 5.27.2
tu ti riferisci alla configurazione generale dei controller? riesci a spiegarmi meglio vediamo se riesco ad aiutarti
roberone
Città: Livorno
Grazie,
vorrei memorizzare il mouse index per i player 1 e 2, e le configurazioni dei tasi per giochi diversi.
Ad esempio su beetle psx ho necessita di avere il bottone1 del mouse come trigger lightgun e il bottone 2 come tasto cerchio.
in giochi il bottone2 deve essere configurato come un tasto diverso.
Ho provato anche Recalbox ed ho lo stesso problema. Quindi il problema sono io.
Aggiungo qualche informazione in base alle prove che ho fatto.
I file vengono salvati, nel file retroarchcustom.cfg vengono scritti i mouse index, ma vengono cancellati quando chiudo il contenuto.
Non vorrei pero' andare troppo OT visto che non è un problema della distrubuzione in oggetto. Nel forum ci sono diverse discussioni che affrontano problemi simili, ma non sono riuscito a trovare soluzioni. Forse è meglio aprire un topic dedicato.
