Batocera 5.25 is out
Eccoci qui, come sempre Batocera anticipa di qualche giorno/settimana la release di recalbox.
I 2 sistemi sono praticamente identici, le principali differenze restano:
la parte web (presente in recalbox e non in batocera)
installazione da sd (batocera ha e recalbox no)
e qualche microcompatibilità dei sistemi (allego file con i miei test personali).
Batocera 5.25 qui potete scaricare la versione adatta a voi
Questo è il changelog:
add: Odroid Go Advance support (Retroarch GUI rotation issues thanks to Lakka Team efforts)
add: netplay
add: if you have more than one .mp4 or .png file in /boot/, a random one is selected as intro (video only if supported!)
add: new tag in gamelist.xml keeping track of playing time in a game
add: Ports section on EmulationStation (Cave Story, Lutro and Doom)
add: Thomson - MO/TO (libretro-theodore)
add: NEC PC-98 (libretro-pc98)
add: Daphne (hypseus)
add: libretro-puae (Commodore Amiga)
add: new "flatten-glow" and "zfast" shader sets
add: run-ahead option for optimized latency on libretro systems (/!\ may impact performance)
add: all RetroAchievements platforms
es: new RetroAchievements screen
es: scan and detect wifi networks
es: screen brightness support
es: display volume in OSD
es: support for static video background effects on systems view
es: (Decoration bezels) New option named "Default_unglazed" same bezels as "Default" ones, but without any glazed old cathodic TV effect.
es: support for group/ungroup (Amiga, MSX and Port)
bump: nvidia-driver (440.59)
bump: lr-mame 0.219
bump: retroarch v1.8.4
bump: libretro core
bump: amiberry to v3.1.2
bump: dolphin-emu to 5.0-11632
bump: fs-uae to 3.0.0
bump: mupen64plus core
bump: scummmvm
bump: vice
bump: citra with QT interface
bump: reicast
bump: kodi to 18.5 (not yet all boards)
bump: buildroot and linux kernel
bluetooth: fix some pairing issues
pads: adapt mapping when no l2 or not joystick2 is found (n64, gamecube)
pads: fixes pad having non centered axis (triggers) (xbox pads). As a drawback, axes are not available until a button is pressed
pads: lots of new controllers added like PS3, PS4, 8bitdo (all controllers), Xbox Adaptive, Retro City and CSL Gamepad
rpi: activation of safe shutdown feature for GPi case added (read the GPi manual how to toggle hardware switch)
rpi: full support of several Retroflag cases (GPi, NesPi+, SuperPi, MegaPi)
3ds: menu to change screen layout (Default, large screen and side by syde)
ppsspp: rewind and fast forward
gamecube: automatically use d-pad if no analog stick is available (for bartop and arcade cabinets)
updated BIOS MD5 checks for some systems
rockpro64: support for Roshambo Retro Gaming Case
rewind disabled by default8
Buon divertimento.
Space81
Grazie Inviati: 4 volte
Re: Batocera 5.25 is out
Messaggio da Space81 »
Ciao e grazie carissimo, cosa intendi per parte web ? Su Recalbox c'è la web console manager dalla quale puoi fare tantissime cose, probabilmente intendi altro per Batocera.
Una curiosità, su Batocera i collegamenti GPIO sono i medesimi di Recalbox ? Se si potrei provarlo senza sbattimenti di cambio cablaggio.
Thanks. :-D
ciao, si intendevo proprio quello, che recalbox ha la parte di gestione (e gioco) anche via web, batocera no
i colelgamenti e i dispositivi usano gi stessi identici diriver
io di solito metto altra sd installto tutto e copio giochi ed imamgini e sei pronto, 10 minuti e provi la nuova versione.
Buon divertimento
