GotScraper - Scraping spaziale!!
Re: GotScraper - Scraping spaziale!!
@Macho72
trovato il tuo bug e corretto (mi auguro :D )
ho ancora 4 punti da chiudere prima di pubblicare, ti aggiorno
Centurion_78
Città: VaralloPombia
Messaggio da Centurion_78 »
@Gothrek ecco il codice di errore che mi è appena uscito.
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
Newtonsoft.Json.JsonSerializationException: Cannot deserialize the current JSON object (e.g. {"name":"value"}) into type 'System.Collections.Generic.IList`1[GotScraper2020C.feel_scrape_stats]' because the type requires a JSON array (e.g. [1,2,3]) to deserialize correctly.
To fix this error either change the JSON to a JSON array (e.g. [1,2,3]) or change the deserialized type so that it is a normal .NET type (e.g. not a primitive type like integer, not a collection type like an array or List<T>) that can be deserialized from a JSON object. JsonObjectAttribute can also be added to the type to force it to deserialize from a JSON object.
Path 'err_code', line 1, position 12.
   in Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
   in Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
   in Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
   in Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
   in Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
   in Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
   in GotScraper2020C.FormPrincipale.AggiornaStatistiche() in D:\Progetti\Source\Repos\GotScraper2020C\FormPrincipale.cs:riga 7297
   in GotScraper2020C.FormPrincipale.BackgroundWorker1_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e) in D:\Progetti\Source\Repos\GotScraper2020C\FormPrincipale.cs:riga 233
   in System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
************** Assembly caricati **************
mscorlib
    Versione assembly: 4.0.0.0
    Versione Win32: 4.8.4250.0 built by: NET48REL1LAST_C
    Base di codice: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
GotScraper2020C
    Versione assembly: 1.0.0.61
    Versione Win32: 1.0.0.61
    Base di codice: file:///M:/Programmi/GotScraper/GotScraper2020C.exe
System.Windows.Forms
    Versione Win32: 4.8.4270.0 built by: NET48REL1LAST_C
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Versione Win32: 4.8.4200.0 built by: NET48REL1LAST_C
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Versione Win32: 4.8.4084.0 built by: NET48REL1
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Infragistics4.Win.Misc.v17.2
    Versione assembly: 17.2.20172.2006
    Versione Win32: 17.2.20172.2006
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.Misc.v17.2.DLL
Infragistics4.Win.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.v17.2.DLL
Infragistics4.Shared.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Shared.v17.2.DLL
System.Configuration
    Versione Win32: 4.8.4190.0 built by: NET48REL1LAST_B
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
UIAutomationProvider
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
LiteDB
    Versione assembly: 5.0.9.0
    Versione Win32: 5.0.9
    Base di codice: file:///M:/Programmi/GotScraper/LiteDB.DLL
Anonymously Hosted DynamicMethods Assembly
    Versione assembly: 0.0.0.0
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
Newtonsoft.Json
    Versione assembly: 12.0.0.0
    Versione Win32: 12.0.3.23909
    Base di codice: file:///M:/Programmi/GotScraper/Newtonsoft.Json.DLL
System.Numerics
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
mscorlib.resources
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
UIAutomationTypes
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Infragistics4.Win.UltraWinStatusBar.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinStatusBar.v17.2.DLL
Infragistics4.Win.UltraWinGrid.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinGrid.v17.2.DLL
Infragistics4.Win.UltraWinDataSource.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinDataSource.v17.2.DLL
Infragistics4.Win.UltraWinTabControl.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinTabControl.v17.2.DLL
Infragistics4.Win.UltraWinTree.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinTree.v17.2.DLL
Infragistics4.Win.UltraWinEditors.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinEditors.v17.2.DLL
Infragistics4.Win.UltraWinListView.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinListView.v17.2.DLL
Infragistics4.Win.UltraWinFormattedText.WordWriter.v17.2
    Base di codice: file:///M:/Programmi/GotScraper/Infragistics4.Win.UltraWinFormattedText.WordWriter.v17.2.DLL
Vlc.DotNet.Forms
    Versione assembly: 3.1.0.0
    Versione Win32: 3.1.0.0
    Base di codice: file:///M:/Programmi/GotScraper/Vlc.DotNet.Forms.DLL
Vlc.DotNet.Core
    Base di codice: file:///M:/Programmi/GotScraper/Vlc.DotNet.Core.DLL
Vlc.DotNet.Core.Interops
    Base di codice: file:///M:/Programmi/GotScraper/Vlc.DotNet.Core.Interops.DLL
Accessibility
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.VisualBasic
    Versione assembly: 10.0.0.0
    Versione Win32: 14.8.4084.0 built by: NET48REL1
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.resources
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.resources.dll
System.Drawing.resources
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_it_b03f5f7f11d50a3a/System.Drawing.resources.dll
FastMember
    Versione assembly: 1.5.0.0
    Versione Win32: 1.5.0.0
    Base di codice: file:///M:/Programmi/GotScraper/FastMember.DLL
FastMember_dynamic
    Base di codice: file:///M:/Programmi/GotScraper/FastMember.dll
System.Windows.Forms.resources
    Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Debug JIT **************
Per abilitare il debug JIT, è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell'applicazione o del computer (machine.config).
L'applicazione inoltre deve essere compilata con il debug
abilitato.
Ad esempio:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
Quando il debug JIT è abilitato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
@Centurion_78
verifico subito
grazie per la pazienza
Centurion_78
Gothrek ha scritto: 19/11/2020, 9:19 @Centurion_78
verifico subito
Non ho controllato fino ad ora, e credo che ci sia un problema: le cartelle dove avrebbe dovuto mettere i vari files (ad esempio [...]\Games\75\Media\Images\Screenshot\ e [...]\Games\75\Media\Videos\) non posso aprirle. Windows mi restituisce questo errore: "Impossibile accedere a <cartella>. La directory o il file è danneggiato e illeggibile."
Quando avevo fatto partire lo scraping avevo controllato che stesse lavorando, ed avevo fatto accesso alle cartelle ed avevo visto una trentina di files. Sai che problema ci può essere? Io ora le cancello, dubito sia un problema di HD (è piuttosto nuovo) e affligge solo le cartelle che avrebbe dovuto "toccare" il programma.
@Centurion_78
sono cartelle normali di windows effettivamente io ci faccio poco se non copiare i file dentro, puoi verificare se hai i permessi per accedervi? strano effettivamente
nel frattempo ho ho visto che la tua segnalazione in questa nuova release l'avevo già sistemata, quindi a breve quando ripubblico la app non dovrebbe piu' presentarsi
Alfa7.2
In questa versione:
Implementazioni:
- modificati i protocolli di sicurezza verso screenscraper per cui su sistemi operativi troppo vecchi si veniva rifiutati (segnalato da @dR.pRoDiGy)
- aggiornata applicazione con le ultime api di screenscraper
- aggiornate le librerie del vlc per cui si produceva un errore (segnalato da @Macho72 )
- aggiunta tabellina per lo status dei server
- aggiunto bottone stop scraping
- eliminate le checkbox per l'edit delle opzioni
Corretti i seguenti bug:
- corretto bug per cui se si guardavano media di un sistema in scraping l'app si bloccava
- corretto errore di digitazione nella creazione del file gamelist
- corretto bug per cui clickacndo sulel opzioni di un sistema in griglia non risultavano aggiornati nella corrispondente tab
- corretto bug per il quale su ricerca di rom per nome su screenscraper non venivano trovati risultati
- eliminato bug per cui veniva automaticamente messo in play il video di una rom alla selezione di un sistema (@adolfo69 )
- corretto bug per la navigazione con le freccie attraverso i tile
- tornata visibile la possibilità di NON copiare le rom nel server media
Macho72
Città: vr
Grazie Inviati: 18 volte
Messaggio da Macho72 »
Gothrek ha scritto: 20/11/2020, 18:32 Alfa7.2
In questa versione:
Implementazioni:
@Gothrek grazie mille del lavoro fatto, adesso parte <-gogogo-> , sto provando a capire come funziona, ma mi lagga un pò ed è lento (forse un problema di trasferimento dati in rete)
vlc devo installarlo comunque?
@Macho72
vlc non serve era una prova
molti sistemi scaricano materiale dal sisto screenscraper, questo sito ultimamente staavendo diversi problemi per cui ha aperto in questo periodo il download solo ad utenti registrati (registrazione gratuita che puoi fare sul loro sito).
Quelle credenziali puoi naturalmente inserirle anche in gotscraper per velocizzare il tutto.
Come fare?
1) scegli il frontend
2) scegli il sistema di cui vuoi fare scraping (doppio click e apparirà nella griglia al centro)
3) click nella cella della griglia relativa al path cosi da specificare dove sono le tue rom
4a) (solo la prima volta), clicka sulla celladella griglia ordine siti (per default avrai 0,1,2) e di rimanda alla sezione dove inserire utente e password di screenscraper. Inseriscile e premi salva
4b) premi avvio scraping
Il programma poi ha 1000 opzioni che magari vediamo dopo il tu oprimo scraping :D
Buon divertimento
Macho72
Città: vr
@Gothrek
Qualcosina sono riuscito a fare, non ha trovato alcune immagini e nessun video (mi sembra siano selezionati di default), ma devo provare a vedere le impostazioni di batocera dove ho qualche problemino con i BIOS.... dove trovarli e se è sufficiente solo copiarli nella cartella bios.... in alcune ricerche dicono di metterli nella cartella roms 🤷‍♂️
@basta che copi il tutto dentro la cartella del sistema corrispondente dentro share\roms\cartelladelsistema
Macho72
Città: vr
Gothrek ha scritto: 22/11/2020, 21:00 @basta che copi il tutto dentro la cartella del sistema corrispondente dentro share\roms\cartelladelsistema
@Gothrek , ma i BIOS io li ho messi nella cartella bios dove per le cartelle ha aggiunto quello che mancava e per i vari file ha sovrascritto a quelli esistenti...... risultato penso corretto perché adesso mi dice che non ci sono bios mancanti....
Macho72 ha scritto: 23/11/2020, 12:21
io non parlavo dei bios, ma delle rom, file gamelist e cartella media per le immagini
Rilasciata versione alfa7.4
Alfa7.4
In questa versione:
Implementazioni:
- ora all'uscita di nuovi sistemi verrà aggirnata la tabella
- modificato campo datarelease nella creazione del file gamelist per coerenza con gli emulstation
- corretto bug per cui il file gamelist presentava iraggiungibilità nel file immagine
- corretto bug per cui se venivano scraperate rom con estensioni minori di 3 il nome immagine non risultava corretto
- corretto bug per cui a volte veniva generata eccezione nella regisrtazione delle statistiche
- corretto bug per cui in ricerche testuali non sempre veniva trovato il genere del gioco
Macho72
Città: vr
@Gothrek ho fatto lo scraping per amiga500, ha trovato solo l'immagine per un gioco a adesso i giochi sono stati rinaminati con il nome di quel gioco... come posso rimediare?
una volta finito lo scraping ho solo guardato in server media la roms e c' era solo quel gioco
Macho72 ha scritto: 28/11/2020, 19:18 @Gothrek ho fatto lo scraping per amiga500, ha trovato solo l'immagine per un gioco a adesso i giochi sono stati rinaminati con il nome di quel gioco... come posso rimediare?
Scusa non ho capito, forse è il sonno.
Il programma non rinomina nessuna rom (ne le tocca).
Fa un controllo con suo codice MD5 sui siti di scraping per vedere se trova qualcosa e nel caso scarica una immagine che si chiama con lo stesso nome.
Aiutami ad aiutarti
Macho72
Città: vr
Gothrek ha scritto: 29/11/2020, 10:16
Aiutami ad aiutarti
scusa ma come si fa a fare questo controllo? non ne ho la più pallida idea....
su amiga500 ho installato 18 giochi e dopo aver fatto lo scrapping adesso si chiamano tutti come il primo della lista, questo è una parte del game list.xlm se può esserti utile..... le path sono diverse, ma il nome è diventato su tutti "Apidya"
il controllo lo fa lui tu non devi far niente, la cosa che mi lascia perplesso è che i giochi per amiga siano .exe?
Macho72
Città: vr
Gothrek ha scritto: 29/11/2020, 15:00 il controllo lo fa lui tu non devi far niente, la cosa che mi lascia perplesso è che i giochi per amiga siano .exe?
ok risolto, infatti i file .exe erano solo un collegamento per il download <-lol-> .... chiedo scusa!
altra domanda, se con lo scraping non mi trova qualche immagine di qualche gioco dove posso recuperarle?
dove posso trovare una guida per il tuo programmino senza doverti disturbare ogni volta? ho visto che ci sono tante impostazioni, di default è già settato con tutto? (immagini, video, ecc.)
es. si può mettere la spunta su "non copiare le rom durante lo scraping" cosa vuol dire?
@Macho72
è una versione alfa, aperta a pochi intimi per fare i test :D guida ancora non ce ne è.
se non le ha trovate, puoi provare 2 strade, nella sezione siti di scraping selezionando ad esempio screenscraper puoi spuntare la voce cerca per titolo, cosi anche se non la trova con l'md5 giusto prova cmq a cercarla per titolo.
In generale i romset di cui si hanno un archivio, sono le no-intro, le altre versioni sono meno diffuse e le rom non machano con i media, pertanto se non li trova (e non vuoi usare la soluzione dicui sopra), ti consiglio di scaricare romset no.intro, altrimenti aggiungerle a mano con immagini trovati su google rasenta la follia, non lo consiglierei neanche al mio peggior nemico :D
la spunta, evita la copia nel server media (fortemente scosigliata), perchè è da li che lui poi ricostruirà i romset nel caso in cui tu in futuro voglia creare altre (un altro rasp, un pc, ecc). Tra l'altro di prossima eliminazione (l'opzione)
Cacy82
Grazie Inviati: 15 volte
Messaggio da Cacy82 »
Ciao a tutti, ho scaricato il zip di gotscraper, ma non trovo all'interno l'eseguibile per farlo partire, ho per caso sbagliato qualcosa?
