[GUIDA] Arcade PC - gioco Arcade basati su hardware PC
le Guide ed i Topic importanti in un unico posto !
Re: [GUIDA] Arcade PC - gioco Arcade basati su hardware PC
TeknoParrot 1.0.0.112
nuovi giochi per i non Patreon:
nuovi giochi per i Patreon:
We have now finally acquired SSL certificate from Comodo the Global Leader in Cyber Security Solutions!
This is basically certification that our emulator contains no malicious code and that we are trusted by virus scanners (No more false positives).
Thank you all for being patient and special thanks to community and especially community developers for insane work rate on other new awesome features present in this release!
Changes in TeknoParrot 1.0.0.112 Release:
- New naming convention because we have now automatic builds coming from AppVeyor.
- This release needs to be completely separate from old version due to lot of changes, you may however copy UserProfiles to this new version.
- [nzgamer41][TeknoParrotUi] Automatic update of TeknoParrotUI, OpenSegaAPI, OpenParrot and OpenParrot64 from Github Releases.
NOTE: This way any approved open source community change is instant to the end users. Such as: Fixes, improvements and more! No more waiting for a month to get community fixes!
- [Reaver][Lindbergh] Games now work again, sorry about that.
- [Reaver][TeknoParrot] TeknoParrot.dll, SteamChild.exe and BudgieLoader.exe are now signed with official COMODO certificate to get rid of false positives on virus scanners.
- [Poliwrath][TeknoParrotUI] Fix controls not working in GRID/Sega Rally/Europa-R games.
- [Poliwrath][TeknoParrotUI] Check if HookedWindows.txt exists before reading it.
- [Nezarn][OpenParrot] Fix OpenParrotLoader argument count
- [Nezarn][Lindbergh] Initial D4 Export SRAM fix.
- [Nezarn][Lindbergh] Virtua Fighter 5 Ver. C home/ram folder fix.
TeknoParrot 1.0.0.118
- Groove Coaster 2
Changes in TeknoParrot 1.0.0.118 Release:
- [Reaver][OpenParrot] Open source GRID and GTI Club 3.
- [Reaver][OpenParrot] Add missing emulated package to Fast I/O emulator. Groove Coaster 2 now boots and is playable.
- [Reaver][OpenParrot] Add missing reg query, used by USF4.
- [Reaver][TeknoParrotUi] Fixed issue where TeknoParrotUI would stay in background after closing.
- [Reaver][TeknoParrotUi] Groove Coaster 2 profile.
- [Poliwrath][TeknoParrotUi] Show EmulatorType in game info.
- [Poliwrath][TeknoParrotUi] Add (Patreon Only) to game names if they have the patreon bool.
- [Poliwrath][TeknoParrotUi] Add Patreon bool to 2Spicy.
- [Poliwrath][TeknoParrotUi] Check iDmacDrv64.dll legitimacy
- [Poliwrath][TeknoParrotUi] Add RequiresAdmin bool to GameProfile, add warning before launch if UI isn't running as admin
- [Poliwrath][TeknoParrotUi] Fix formatting/clean up GithubUpdates slightly
- [Poliwrath][TeknoParrotUi] Change GRID and GTI Club 3 emulator to OpenParrot
- [nzgamer41][TeknoParrotUi] Fix autoupdate issues.
Game Loader All RH 331
Updated contents of 331
-Supported TP v1.0.0.112.
* As before, the following game has problems because it uses "--emuonly" argument.
Mach Storm (I / O ERROR).
Pokken (Failed to Load DLL!).
Wangan (Failed to Load DLL!).
All Lindbergh (Crash). * Because the game side refers to the data in the TP folder, not the game folder.
Support for Shining Force Cross Elysion.
* Please set the command line option from "Loader setting 1" tab.
* If the command line option does not use "-hdtv", the in-game mouse cursor position will shift.
* When you start in window mode, please set "Window size" tab "Monitor resolution" to "1280x720" and command line argument to "-hdtv".
* Since this game is OpenGL like Cross Raid, you can not change the window size freely.
-Fixed a bug that a timeout error occurs in some Lindbergh games.
-Fixed a bug that can not be displayed properly when setting full screen ID5.
-Fixed a bug that GTI Club crashes.
-Removed the selection of SR3's completely meaningless start method.
-Other bug fixes that I noticed.
・ Set Language.ini as default.
・ Please execute Game Loader Installer.exe first.
・ If not working properly, discard this Loader to the trash can and end.
Game Loader All RH 332
Update contents of 332
Finally, Silent Hill Arcade is now playable on Windows 10! . Thanks to MOHKERZ
* I tried running SHA after a long time, fixed some of the things I was interested in.
* Fixed a bug that crashes when playing movie when "LoaderMode = dg" is set.
* There are minor drawing problems when "LoaderMode = dg" is set.
* Added window mode when setting "LoaderMode = dg".
* When setting high resolution, set "Window Mode", "LoaderMode = dg", and set "Resolution" of "Game Loader dgVoodooCpl.exe" to 4: 3 resolution.
* Example If the monitor size is 1920x1080, it is 1440x1080.
* When full screen is set, the position of the mouse cursor will shift if "Resolution" is not set to 1920x1080.
* When the window mode is set, display of bezel image is also supported.
* Please change "CrossHair.ani" or "CrossHair.cur" to "sv" folder for change of mouse cursor.
* If you fail to change the mouse cursor when launching Loader, please press "CTRL + F" after game loading is over (you may need to press more than once).
* When entering test mode, set to LoaderMode other than "LoaderMode = dg".
* Setting video
TeknoParrot 1.0.0.122
- Darius Burst Another Chronicle
Changes in TeknoParrot 1.0.0.122 Release:
STATEMENT BY REAVER
Full open source is closing in on us. The more contributions and support we get from community developers, the more we will open source.
Do you understand the magnitude of what we can do with the ElfLoader?
Basically run ANY/ALL linux games on Windows like Wine does for Linux.
Especially now that our elfloader can emulate even libs(.so)!
The following months will tell us what will happen, if support is great and community is friendly. All source code will go public.
Special thanks to Nezarn, Boomslangnz, sTo0z, nibs and nzgamer41 for working on stuff tirelessly with me and keeping me motivated despite all the hate.
And remember, none of the Patreon funds come to me for personal use.
All of the money goes to developers and hardware to get more work done.
- [Reaver/Nezarn][OpenParrot] Darius Burst Another Chronicle is now supported, open source ftw.
NOTE: You can play up to 4 players!
NOTE: 2nd screen is not inverted, truly epic achievement by Nezarn. Best things come first in TeknoParrot as always!
NOTE: Test Switch does not work right now, will log on real cabinet at some point to fix this issue.
NOTE: Copy folder b74e8ba0fff8b4f7b32099c84f9d1c23_000 to gamedir and rename to Db74e8ba0fff8b4f7b32099c84f9d1c23_000
NOTE: Copy folder EDData to gamedir and rename to DEDData
NOTE: NESYS is emulated, enjoy lots and lots of missions/modes!
NOTE: Here is proper config for init.ini:
2720
768
60
0
0
1
0
0
1
1
0
0
NOTE: 4th parameter is fullscreen.
Feel free to change resolution, best played on ultra wide monitor.
- [Reaver][OpenParrot] Fast I/O emulator now supports 3 and 4 player controls.
- [Reaver][OpenParrot] Fast I/O emulator improvements.
- [nzgamer41][TeknoParrotUi] fixed the patreon page
- [nzgamer41][TeknoParrotUi] fixed focus on the listbox
- [nzgamer41][TeknoParrotUi] fixed it so it'll remember what you clicked on when you go to settings
Game Loader All RH 333
Update contents of 333
-Supported the DBAC of TP v1.0.0.122.
* Repeat again, but be sure to disable the window mode on the TPUI side.
* Setting video http://y2u.be/6h7DadAFmIc
-Added window mode to LoaderMode = dg.
* There are bugs such as crashes in many games.
・ Haunted Museum 1 "Loader Mode = dg" support mouse cursor reading in "window mode".
* When using, set "LoaderMode = dg" and copy "Crosshair.ani" or "Crosshair.cur" to the sv folder.
* If there is Crosshair.ani and Crosshair.cur, Crosshair.ani is read preferentially.
* Please disable the "Update interval other tab" "Update interval for hiding mouse cursor" so that the mouse cursor does not disappear.
* Don't forget to set it to "MULESUM.ini" FULLSCREEN 1 "(resolution: 1024x768).
* The cursor does not reverse even if you enter the mirror mode during the game.
* Since the window mode, also supports the display of the bezel image.
* There is a bug that two mouse cursors may be displayed and a bug that Crosshair.ani does not animate.
* The function to limit the movement amount of the mouse can not be used.
-Fixed a bug that the screen becomes full screen regardless of the window mode when the Silent Hill Arcade is set to LoaderMode = 0.
aggiunti in prima pagina nuovi link per scaricare i giochi
Arcade Games - Taito Type X.zip https://1fichier.com/?knhmq4qoawr02axbvfvh
Arcade Games - Taito Type X+.rar https://1fichier.com/?lehyys8lh6lue6q8nrr2
Arcade Games - Taito Type X2.rar https://1fichier.com/?ii1g2o2ueytw3slozj9n
Arcade Games - Taito Type X2 [missing "Senko No Ronde Duo - Dis-United Order (2009).zip"] https://1fichier.com/?204iajzpomdff3d7376h
Arcade Games - Taito Type X3.zip https://1fichier.com/?fk55aauzqmoufctu57jh
Arcade Games - Taito NESiCAxLive System.zip https://1fichier.com/?7ergema05dav8ys6rsvi
Arcade Games - EXAMU eX-BOARD.zip https://1fichier.com/?b8awmoedhhkbp5nvrii3
Arcade Games - SEGA Ringwide.zip https://1fichier.com/?934l6jzsht71dpvv9wtl
Arcade Games - SEGA Lindbergh YELLOW.zip https://1fichier.com/?iau1nznmdm9h911zff34 (password: Adei)
Arcade Games - SEGA Europa-R.zip https://1fichier.com/?t10ili29f80jwi4aicbo
Arcade Games - KONAMI BEMANI PC HARDWARE (Type3 Variant1).zip https://1fichier.com/?9kymysqv37gi7z0kwmwb
Arcade Games - NAMCO SYSTEM 357 - SYSTEM 359.zip https://1fichier.com/?9icmmv93rn513nm1xrpb
Arcade Games - Various Systems.zip https://1fichier.com/?duqo5tu53ka2p2wsjmnx
Real Arcade 4 PC [UNEMULATED].zip https://1fichier.com/?e423ff92lcdqv1k9r56z
Real Arcade.zip https://1fichier.com/?v8o6er27o4yc1stnwo1f
Zazie
Città: Kenya
Messaggio da Zazie »
Ma non si può mettere gioco per gioco? Non ho spazio su SSD per scaricare 36 gb.
P.S. Teknoparrot è sempre peggio... ? Ormai non conto gli errori che mi compaiono ogni volta che avvio un gioco...
Zazie ha scritto:Ma non si può mettere gioco per gioco? Non ho spazio su SSD per scaricare 36 gb.
Mi sembra già bella cosa che si possano scaricare. Esistono anche dei torrent dove puoi prendere giochi singoli, ma hanno di solito vita breve
Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk
"MODerrare humanum est"
^F117^
Messaggio da ^F117^ »
Tutti i link sono down.
^F117^ ha scritto: 15/04/2019, 22:24 Tutti i link sono down.
quali? gli ultimi pubblicati funzionano
^F117^
Impossibile raggiungere il sito Connessione negata da 1fichier.com.
Prova a:
Verificare la connessione
Controllare il proxy e firewall
ERR_CONNECTION_REFUSED
^F117^ ha scritto:Impossibile raggiungere il sito Connessione negata da 1fichier.com.
Prova a:
A me funziona, sicuro che il tuo ISP non blocchi qualcuno di questi siti? Quali DNS usi?
xbrunox
Città: castellanza
Messaggio da xbrunox »
Dns di Google, di fastweb e di Vodafone... Non funzionano...
Non funzionano neanche a me, presumo siano bloccati da alcuni provider
alucard
Città: MotherEarth
Grazie Inviati: 5 volte
Grazie Ricevuti: 15 volte
Messaggio da alucard »
Avete provato con TorBrowser?
Con Tor infatti funzionano
TeknoParrot 1.0.0.140
- Let's Go Safari
- Rambo
purtroppo con il nuovo sistema di aggiornamento continuo non è facile accorgersi delle nuove versioni di TeknoParrot, ma soprattutto non è più disponibile un whatsnew testuale e un elenco certo dei nuovi giochi (bisogna individuarli a mano)
comunque hanno aggiunto Rambo per i Patreon!
nuova versione di TeknoParrot 1.0.0.154 (in realtà le versioni nuove sono già state diverse con il nuovo sistema di aggiornamenti automatici)
uno dei giochi disponibili per i soli Patreon è stato reso disponibile a tutti:
Counter-Strike Neo - カウンターストライク ネオ (2003) [Namco N2]
Zazie
Città: Kenya
Scusate, ma come "wheel axis" cosa metto? Non funziona niente!!
