Re: [RELEASE] FEEL FRONTEND 1.9
Inviato: 09/11/2015, 11:19
Errore mai visto!
Rispetto alla config standard, puoi spiegare che modifiche hai fatto?
http://wiki.arcadeitalia.net/
Penso niente di particolare, ho modificato solo i tasti in feel.ini , e i vari percorsi in mame.inidR.pRoDiGy ha scritto:Errore mai visto!![]()
# Front-End Emulator Launcher #
# Copyright © FEELTeam Software 2015 #
# System Settings
# 1 = test mode (windowed) | 0 = standard mode (fullscreen)
test_mode 0
# 1 = layout test mode (highlight labels: useful for layout design) | 0 = standard mode
layout_test_mode 0
# 1 = change resolution according to layout | 0 = no resolution change
switch_res 1
# Screen rotation support (for vertical CRT's cabs)
# 0 = none ( = horizontal screen)
# 1 = rotate 90° ( = vertical screen)
rotate_screen 0
# FE Settings
platform_list arcade, computer, console
current_platform arcade
current_layout sheet
fulltext_search 0
# managed by system: no need to touch here!
autostart_mode 0
autostart_single_game arcade|mame|mame-0|strhoop
last_game_played arcade|mame|mame-1|mslugx
# Exit Menu Items
exit_to_windows_menu_enabled 1
restart_windows_menu_enabled 0
shut_down_menu_enabled 1
standby_menu_enabled 0
hibernate_menu_enabled 0
# Keyboard
# min / max keyboard scroll rate (milliseconds)
keyboard_scroll_rate 225
keyboard_min_scroll_rate 20
# Mouse
# 0 = no mouse support | 1 = x-axis | 2 = y-axis
use_mouse 0
# mouse scroll rate
mouse_scroll_rate 20
# mouse deadzone (pixels)
mouse_sensitivity 5
# Joypad
# 1 = yes | 0 = no
use_joypad 0
# 0 <= DeadZone >= 5000 (for analog axes)
joypad_dead_zone 2500
# ScreenSaver
# 1 = on | 0 = off
screen_saver_enabled 1
# seconds
screen_saver_delay 30
screen_saver_slide_time 5
# ScreenShot
screenshot_original_size 0
screenshot_width 320
screenshot_height 240
screenshot_stretch_to_fixed_size 1
# Sound FX
sound_fx_list list.wav
sound_fx_menu menu.wav
sound_fx_confirm confirm.wav
sound_fx_cancel cancel.wav
sound_fx_volume 100
# Background Music
music_path gems.wav
music_volume 50
# Videosnap
# seconds
video_delay 2
# 0-100
video_volume 30
# 1x - 1.5x - 2x ...
video_speed 1
# Input Commands
# Keyboard codes
# A ... Z
# 0 ... 9
# LAlt = Left Alt
# LControl, LCtrl = Left Control
# RControl, RCtrl = Right Control
# LWin = Left Windows
# RWin = Right Windows
# Tab = Tab key
# Space = Spacebar
# Backspace = Backspace
# Enter, Return = Enter
# Pause = Pause
# Escape, Esc = Esc
# PageUp = Page Up
# PageDown = Page Down
# End = End
# Home = Home
# Insert, Ins = Ins
# Delete, Del = Del
# NumPad0 ... 9 = NumPad keys
# Multiply = *
# Add = +
# Subtract = -
# Divide = /
# F1..F12 = Function keys
# None = No key (useful to totally disable a keypress)
# JoyPad codes
# JoyUp
# JoyDown
# JoyLeft
# JoyRight
# JoyB1 ... 15
# NOTE: action_key and menu_key are also used as menu_ok and menu_cancel
action_key q
menu_key 5
menu_ok a
menu_cancel s
menu_up Up
menu_down Down
menu_left Left
menu_right Right
previous_game Up
next_game Down
previous_letter_game d
next_letter_game c
previous_page Left
next_page Right
find_game x
select_platform f
select_emulator j
select_gamelist z
next_platform
next_emulator
next_gamelist
previous_platform
previous_emulator
previous_gamelist
add_game_to_list l
remove_game_from_list 9
show_custom_image
show_game_info h
show_exit_menu w
screensaver_previous_game
screensaver_next_game
next_sort
reload_config
# SmartASD USB interface (commands, LEDs, etc.) support
# 0 = none (no SmartASD present)
# 1 = shared mode (single SmartASD for commands and LEDs = 5 LED channels per player)
# 2 = dedicated mode (SmartASD dedicated to LEDs = 13 LED channels per player)
# 3 = dedicated mode with 6 buttons (SmartASD dedicated to LEDs = 13 LED channels per player)
smartasd_mode 0
# 1 = enable SmartASD debug mode (display LED status on screen) | 0 = no debug
smartasd_debug_mode 0
# * = use first SmartASD available
smartasd_id *
# set commands used during list browsing and menu (relevant LEDs will be highlighted)
frontend_list_controls joy1|start1|bt1-1|bt1-2|dial1|joy2|start2|extra1|side1|side2
frontend_menu_controls joy1|start1|bt1-1|bt1-2|dial1|start2|extra1|side1|side2
service_mode 1
service_mode_available 1
# FEEL OTA update
# 1 = enable upgrading to beta versions too | 0 = no beta versions
update_beta 1
feel_uuid 11111111-1111-1111-1111-111111111111Codice: Seleziona tutto
# Copyright © FEELTeam 2015 #
emulator_title M.A.M.E.
gamelist_list mame-0, mame-1, mame-2, mame-3
current_gamelist mame-1
rom_path C:\Documents and Settings\Simo\Desktop\mame\roms
# 0 = default rom list
# 1 = use mame xml list
# file catver.ini is optional (must be in the same folder)
# 2 = load settings from settings file: [rom_path]\[rom_name].[rom_extension]
# 3 = use mame list info (requires DatUtil from http://www.logiqx.com )
# Settings .ini file structure:
# emulator_commandline ...
# emulator_arguments ...
# input_mapping ...
# use this for game that needs different settings
# (eg. pc games need to be lauched in different path, so you create one file per game that contains
# exe path in emulator_commandline)
list_type 1
# multiple rom extension allowed only in default rom list (list_type = 0) and must be comma
# separated
rom_extension zip
# nms_file must be placed in rom_path
# nms_file structure:
# [rom_description] | [rom_name]
nms_file
# it's only used in list creation if emulator_commandline not contains emulator path directly, but,
# for example, a wrapper or a program that launch emulator in second time
emulator_path C:\Documents and Settings\Simo\Desktop\mame
# HiToText Settings (only for mame):
hitotext_exe_path C:\HiToText\HiToText.exe
hiscore_path C:\Documents and Settings\Simo\Desktop\mame\hi
nvram_path C:\Documents and Settings\Simo\Desktop\mame\nvram
# ARGUMENTS KEYWORD:
# (allowed in pre_emulator_app_arguments, emulator_arguments and post_emulator_app_arguments)
# [rom_path] | [rom_name] | [rom_extension] | [full_path] | [full_dos_path]
# [full_path] = [rom_path]\[rom_name].[rom_extension]
# [full_dos_path] = [full_path] in dos format (8.3)
# # = no argument
# run a process before emulator
pre_emulator_app_commandline
# run emulator
emulator_commandline C:\Documents and Settings\Simo\Desktop\mame\mameuifx.exe
emulator_arguments [rom_name]
# 1 = yes | 0 = no
emulator_nodosbox 1
# run a process after emulator
post_emulator_app_commandline
# use this if you want to remap some key (useful for mapping quit combination key)
# eg.:
# ESC::LAlt+X -> remap esc key with combination Left Alt + X
# A::B -> remap A key with B key
# multiple settings must be comma separated (eg.: ESC::LAlt+X,A::B).
# See feel.ini for complete key list
# input_mapping not working with emulators that runs with input exclusive mode (like mame)
input_mapping
# snapshot is also used by screen saver
snapshot_path C:\Documents and Settings\Simo\Desktop\mame\snap
video_path C:\Documents and Settings\Simo\Desktop\mame\video
cabinet_path C:\Documents and Settings\Simo\Desktop\mame\cabinets
marquee_path C:\Documents and Settings\Simo\Desktop\mame\marquees
# take effect only in the all-games list
show_clones 0
#emulator_useshell 0
snapshot_extension png
cabinet_extension png
marquee_extension png
current_layout wood
#mess_machine dR.pRoDiGy ha scritto:Okkei, bug trovato e fixato.. v.1.9.1.2 disponibile in auto-update
Aston Belt | astron
Badland|bad l ands
Bega's Battle | bega
Cliff Hanger | cliff
Cobra Command | cobra
Esh's Aurunmi l la|uvt
Galaxy Ranger | galaxy
GP World | gpworld
Interstellar | interstellar
Super Don Quix-ote | sdq
Us vs Them | uvt
Road Blaster | roadblaster
Star Blazer | blazer
M.A.C.H. 3 | mach3Codice: Seleziona tutto
emulator_title Daphne
gamelist_list daphne-0
current_gamelist daphne-0
rom_path C:\Documents and Settings\Simo\Desktop\Daphne\vldp
rom_extension txt
nms_file daphne.nms
list_type 4
emulator_commandline C:\Documents and Settings\Simo\Desktop\Daphne\daphne.exe
emulator_arguments [rom_name] vldp -framefile "[full_path]" -fullscreen -nohwaccel -noserversend -x 640 -y 480
emulator_nodosbox
snapshot_path C:\Documents and Settings\Simo\Desktop\Daphne\snap
current_layout Daphne
#emulator_path .\mame
#hitotext_exe_path .\hitotext.exe
#hiscore_path .\mame\hi
#nvram_path .\mame\nvram
#pre_emulator_app_commandline
#pre_emulator_app_arguments
#post_emulator_app_arguments
#input_mapping
#cabinet_path .\mame\cabinets
#marquee_path .\mame\marquees
video_path C:\Documents and Settings\Simo\Desktop\Daphne\movies
#show_clones 1
#mess_machine
#cleanup_names 0
show_clones 1
cleanup_names 0
--DAPHNE version 1.0.12
--Command line is: C:\Documents and Settings\Simo\Desktop\Daphne\daphne.exe -listxml
--CPU : AuthenticAMD 2300 MHz || Mem : 2048 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce 210
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
ERROR: Unknown game type specified : -listxml
Bad command line or initialization problem (see daphne_log.txt for details).
To run DAPHNE, you must specify which game to run and which laserdisc player you are using.
For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode.Beh ma facendo così si vedrebbero cmq molti snapshot "vuoti" durante lo scorrimento.. non il max. Preferisco, semmai, rivedere in meglio tutta la procedura di visualizzazione degli snap (precisamente rendendola asincrona => la lista scorre, e le immagini arrivano "con calma" appena possibile), di modo da poter rendere l'interfaccia responsiva al massimo in tutte le condizioni. Ci penserò..antoniomauro ha scritto:Potresti caricare la snap del parent (se manca quello del clone ovviamente) nello stesso processo temporizzato dell'avvio del video, magari 1/2 secondo prima del lancio del filmato stesso!
Al momento l'auto-update non si può spegnere.. ma penso sia solo un vantaggio, gli aggiornamenti contengono sempre piccole migliorie e bugfixing, quindi è buono riceverli. Non voglio cmq "spammare" troppo, i prossimi update arriveranno con un minimo di calmaantoniomauro ha scritto: Approfitto per chiederti una cosa (forse banale):
E' possibile disattivare il processo di auto-update? Continuerai a pubblicare gli aggiornamenti in maniera "tradizionale"?
Anch'io ti amo.. grande capo dei meganoidi !!!Don Zaucker ha scritto: [...]
Consiglio: per il mame volevo modificare la cartella delle roms con clrmame apposta per Feel con i working+noclone ma visto che poi rischio che qualche gioco non funzioni preferisco usare romlister e creare un XML su misura, mantenendo quindi inalterata la cartella roms. Che ne pensate ?
Domanda: adesso comincerò la configurazione di Feel per i sistemi Amiga, c64, vic20 e intellivision, per emularli devo usare un emulatore dedicato o mi conviene usare il nuovo mame con MESS incorporato ? Sempre tenendo presente sua maestà Feel. ;D
Saluti.
p.s.: amo Prodigy
