CRT EmuDriver- Driver ATI 15Khz nativo e tools x risoluzioni
Le Guide ed i Topic importanti in un unico posto !
moket
Medaglie: 25
Re: Driver ATI 15khz nativo e tools per gestire le risoluzio
Messaggio da moket »
Calamity ha scritto:Hi moket,
I'm very sorry that it didn't work.
Thanks Calamity but dont worry. You are very friendly guy. <-kissed->
Calamity ha scritto: If you still wan't to keep your card try using the drivers provided by the manufacturer and use VMMaker over them, just limit the TotalModes to 60 and there's a possibility that it could work. Consider sending me the original drivers so I can dig in them to see if there's something we're missing.
All this is happened because i want "the best" on my MAMECAB. Sega model 2 emulator dont run very well whit my 9250 because it dont support a Pixel shaded 2.0 (3.0 is better) but run perfect whit mame. This is the reason for i will change my card. Can i do this on my HD4650 whit your help???????? If not, which is the best ATI video card AGP for use in my mamecab that support all modelines in mame and support the pixel shaded 2.0 or higher???
Calamity, you are very serious person and i would like your council.
If you want, i send to you all you want however for work on my hd 4650 to adapt them for your greate driver.
Many thanks friend <-flowers->
moket
Medaglie: 25
Re: CRT EmuDriver- Driver ATI 15Khz nativo e tools x risoluz
Comunque sia ho trovato una ATI 9800pro 256 BIT. Molto probabilmente è la miglior scelta per risolvere il mio problema...
Ho visto che questa scheda è (ancora) fenomenale \:D/
user9999
Città: Cuneo
Messaggio da user9999 »
ho una motherboard con AGP 4x, quale potrebbe essere la scheda video migliore compatibile con i driver di Calamity?
vado sul sicuro con una radeon 9250 agp 256mb, o meglio una più recente?
<-help2->
Se devi usare il cab solo con mame o con emu che richiedono poche "risorse", la 9250 e' sempre perfetta ;)
user9999
Città: Cuneo
infatti pensavo a quella scheda, però guardando l'elenco su wikipedia delle schede ati forse potrei prendere (usata) una scheda più performante, tipo una 9800 oppure una x850... sono compatibili con i driver di Calamity? <-think->
user9999 ha scritto:forse potrei prendere (usata) una scheda più performante, tipo una 9800 oppure una x850... sono compatibili con i driver di Calamity? <-think->
In ogni caso se la usi solo con mame nn serve una scheda + performante, qui trovi una lista delle schede sicuramente compatibili con calamity:
http://postback.geedorah.com/foros/view ... hp?id=1424
user9999
Città: Cuneo
si la userei solo con mame (per ora...)
se ho capito bene lo spagnolo, solo le schede evidenziate in neretto sono testate al 100%
mucias gracias por el link 8-)
A mio parere se la scheda ati e' compatibile con soft15khz lo e' assolutamente anche con i driver di calamity, i driver sono in pratica gli stessi, solo che nel caso di soft15khz le modeline vengono registrate dal tool soft15khz, mentre sui driver di calamity sono gia' incorporati nel file di installazione
user9999
Città: Cuneo
PaTrYcK ha scritto:A mio parere se la scheda ati e' compatibile con soft15khz lo e' assolutamente anche con i driver di calamity, i driver sono in pratica gli stessi, solo che nel caso di soft15khz le modeline vengono registrate dal tool soft15khz, mentre sui driver di calamity sono gia' incorporati nel file di installazione
ottimo, in effetti il ragionamento fila!
Quindi posso anche considerare le schede ati agp segnalate come compatibili con soft15khz <-thumbup->
ho trovato queste, elencate in ordine di potenza crescente:
ATI Radeon 9250 AGP
ATI Radeon 9500 PRO AGP
ATI Radeon 9550 AGP
ATI Radeon 9600 PRO AGP
ATI Radeon X1650 PRO AGP
ATI Radeon HD3850 AGP
qualche consiglio prima che mi fiondi su ebay a cercare l'affare? <-Gelato->
moket
Medaglie: 25
Secondo me non ti conviene andare oltre la 9800pro.
X1650 (come diceva calamity) già potrebbe crearti problemi.
Fai come dice Patrick: 9250 e vai bene. Io la uso tuttora e và che è una meraviglia con il (solo) mame.
Kernel aveva linkato una lista delle schede provate e la 9250 (come la 9800) funziona perfettamente con i driver di Calamity.
user9999
Città: Cuneo
moket1978 ha scritto:Secondo me non ti conviene andare oltre la 9800pro.
Grazie, allora restringo la ricerca a 9250 e 9800
:love:
user9999 ha scritto:Grazie, allora restringo la ricerca a 9250 e 9800 :love:
Sul mio cab ho una 9200, puoi tranquillamente aggiungere alla lista, in pratica e' identica alla 9250 !!!
Jomy
Città: BassanoDelGrappa
Messaggio da Jomy »
Stavo pensando al seguente setup:
- Sanwa 29" a 31Khz
- Drivers Calamity 6.5 (per ora, spero in una 4850 dopo natale)
- Groovy Mame per la "magia" :)
Come rende l'accoppiata dei drivers + Groovy nei monitor Tri-Freq VGA? Qualcuno ha sperimentato?
Naomi Universal: JVS-PAC + Calamity ATI Drivers XP + GroovyMAME
moket
Medaglie: 25
PaTrYcK ha scritto:Sul mio cab ho una 9200, puoi tranquillamente aggiungere alla lista, in pratica e' identica alla 9250 !!!
Quoto Patrick: Anke io l'ho provata e non ho trovato alcuna differenza tra la 9200 e la 9250.
user9999
Città: Cuneo
Alla fine ho preso una ATI RADEON 9250 AGP 256MB a 15€ 8-)
Ora, per l'update da soft15khz ai driver di Calamity farei così:
-rimozione soft15khz
-rimozione vecchi driver Nvidia
-installazione scheda
-installazione driver Calamity
giusto? <-think->
Direi di si
<-Gelato->
Exander
Città: Padova
Messaggio da Exander »
Domanda da un milione di dollari, e per me che ho girato il monitor in verticale, visto che gli shot'em up sono i miei preferiti funziona la cosa?
Con Groovy arcade linux e la x800 non ci sono proprio riuscito :(
Dr_Zero
Città: Thiene
Messaggio da Dr_Zero »
funziona senza problemi 8-)
user9999
Città: Cuneo
Ola! finalmente sono entrato anch'io nel club di Calamity \:D/
ieri ho sostituito la vecchia geforce4 con una radeon 9250 e ho installato i driver, poi ho lanciato vmmaker sul darkmame...
...poi ho testato il tutto con puckman e... com'è che ora vedo lo schermo piccino piccino? prima con soft15khz si vedeva a pieno schermo <-on_confused->
...poi la morosa mi ha richiamato all'ordine, e non ho potuto smanettare oltre... <-on_rolleye->
...mi sa che devo rileggermi per bene le 26 pagine di questa discussione :on_cry:
Che setaggi hai imposto nel vmaker.ini?
Che risoluzione hai sul FE?
