Visual Pinball e Batocera39 ma a qualcuno funziona?
Il posto giusto per condividere i progetti di Flipper Virtuali e Autocostruiti
waltao57
Città: Popoli
Messaggio da waltao57 »
Salve,
Sto provando da giorni a far girare qualche file di flipper usando il visual Pinball su Bato39 ma... niente.
Le ho provate credo quasi tutte compresi gli scripts vpx di jsm174 https://github.com/jsm174/vpx-standalone-scripts ma al momento nulla.
Metto la parte finale del log del lancio dei giochi che si ferma sempre sullo stesso punto.
2024-03-28 22:24:22.309 INFO [17733] [CodeViewer::LoadFromFile@1928] filename=/userdata/roms/vpinball/Ateam/TheATeam.vbs
2024-03-28 22:24:22.310 INFO [17733] [VPinball::LoadFileName@1194] UI Post Load Start
2024-03-28 22:24:22.310 INFO [17733] [VPinball::LoadFileName@1211] UI Post Load End
2024-03-28 22:24:22.310 INFO [17733] [PinTable::Play@2328] Starting Play mode [table: The A Team , play mode: 0]
2024-03-28 22:24:22.310 INFO [17733] [ProgressDialog::SetProgress@83] 1%
2024-03-28 22:24:22.311 INFO [17733] [PinTable::Play@2448] Duplicating parts for live instance
2024-03-28 22:24:22.319 INFO [17733] [PinTable::Play@2480] Duplicating collections
2024-03-28 22:24:22.319 INFO [17733] [PinTable::Play@2518] Implicit Textbox DMD added: name=ImplicitDMD
2024-03-28 22:24:22.319 INFO [17733] [PinTable::Play@2544] Implicit Flasher DMD added: name=ImplicitDMD2
2024-03-28 22:24:22.319 INFO [17733] [PinTable::Play@2571] Compiling script
2024-03-28 22:24:22.335 INFO [17733] [PinTable::Play@2610] Creating player
2024-03-28 22:24:22.336 INFO [17733] [Player::CreateWnd@580] Creating main window
2024-03-28 22:24:22.562 ERROR [17733] [Player::CreateWnd@612] Failed to find a display mode matching the requested refresh rate [0]
2024-03-28 22:24:22.563 INFO [17733] [Player::CreateWnd@642] SDL display mode: 1680x1050 60Hz SDL_PIXELFORMAT_RGB888
2024-03-28 22:24:22.563 INFO [17733] [Player::Init@1280] Initializing player
2024-03-28 22:24:22.563 INFO [17733] [ProgressDialog::SetProgress@83] Creating Live Table... 10%
2024-03-28 22:24:22.564 INFO [17733] [Player::Init@1341] Initializing renderer (global states & resources)
2024-03-28 22:24:22.570 INFO [17733] [RenderDevice::CreateDevice@1003] Drawable Size: width=1680, height=1050
2024-03-28 22:24:22.570 INFO [17733] [RenderTarget::RenderTarget@43] Backbuffer channel size: 8, 8, 8
si stoppa sempre qui.
Non so che pesci prendere.
Future Pinball funziona bene ma non mi piace perchè il joypad è impossibile da usare.
Serve un aiutino.
Walter
Città: Mondovi
Grazie Inviati: 143 volte
Grazie Ricevuti: 110 volte
Re: Visual Pinball e Batocera39 ma a qualcuno funziona?
Messaggio da Rockman84 »
Ciao
Personalmente non ho mai utilizzato flipper tramite Batocera.
Posso solo provare a linkarti alcune info. Magari le hai già viste ma tant'è...
La wiki "ufficiale" del Visual Pinball su Batocera
https://wiki.batocera.org/systems:vpinball
Video tutorial in lingua inglese relativo a Batocera 38 (per la 39 non ne ho trovati)
https://youtu.be/WWaK60PSMRs?si=J3vJzokCySeA1dbo
Buona giornata
waltao57
Città: Popoli
Ringrazio per la risposta, ma è proprio da lì che vengo, sia il wiki che su youtube sembra sia possibile addirittura facile ma in pratica nisba
Città: Mondovi
Hmm ..allora mi tocca alzare bandiera bianca dato che, appunto, non ho mai utilizzato flipper.
Aspettiamo (e speriamo) che intervenga qualche utente che sappia invece indirizzarti meglio
A guardare il log, l' unica stringa con errori è questa, ammesso di essere sulla strada giusta:
Che possa essere un problema relativo alla risoluzione/refresh rate utilizzati?
raccontaci della configurazione hardware...anzi prima di farlo aggiorna l'avatar di default per favore.
waltao57
Città: Popoli
Risolto!!!!
Come immaginavo era questione di scheda grafica. Quella incorporata nella cpu I7 funziona fino a un certo punto. Montata una nVIDIA GTX 1050 2Gb (comprata usata a 50 euro) riconosciuta al volo senza far nulla e i tavoli si caricano .
Inoltre mi girano anche i giochi ps3 e xbox che prima non partivano, forse perchè ora si caricano i driver GL12 forse.
joecas
Città: bologna
Messaggio da joecas »
Sto provando anch'io visual pinball, ma con batocera 41
Mi sembra vada abbastanza bene.
L'unica cosa che non capisco è come funziona la moadalità fullscreen.
In pratica quello che vedo è questo:
Mentre con visual pinball per windows vedo questo:
Non so quale opzione attivare per ottenere che il tavolo sia visto a tutto schermo, se non usare i vari zoom, ma così dovrei farlo per ogni tavolo.
Qualche suggerimento ?
giotta
Città: Vicenza
Grazie Ricevuti: 9 volte
Messaggio da giotta »
Qualcosa non torna, scusa la domanda, ma batocera cos è ?
joecas
Città: bologna
giotta
Città: Vicenza
Scusa, ma questo batocera non dovrebbe limitarsi a lanciare l'exe del tavolo a cui vuoi giocare ?
Sembra quasi che ti abbia sputtanato lo script del POV all'interno di vpx, non ha molto senso la cosa.
joecas
Città: bologna
giotta ha scritto: 05/02/2025, 15:28 Scusa, ma questo batocera non dovrebbe limitarsi a lanciare l'exe del tavolo a cui vuoi giocare ?
Si lo avevo pensato anch'io, poi studiando meglio ho capito che essendo la versione standalone di visual pinball,
necessita di accorgimenti particolari. Nello specifico bisogna esportare il pov dalla versione windows e metterla assieme al file vpx.
Ad oggi mi rimane solo da capire come posizionare il dmd sul backglass.
La versione windows è sicuramente più semplice da gestire, ma togliersi dalle pa**e windows non ha prezzo.
giotta
Città: Vicenza
Lo devi fare dal B2s server, va nella cartella dove lo hai installato, c è un file exe fatto apposta per il posizionamento del dmd e del backglass
joecas
Città: bologna
giotta ha scritto: 12/02/2025, 14:33 Lo devi fare dal B2s server, va nella cartella dove lo hai installato, c è un file exe fatto apposta per il posizionamento del dmd e del backglass
Magari…
Batocera é su linux, niente file exe 😜
giotta
Città: Vicenza
Il file exe serve solo per creare il file txt dove ci sono le coordinate del dmd e del backglass
Torna a “Flipper Autocostruiti e Virtuali”
