Batocera 39
- Grazie Ricevuti: 375 volte
Batocera 39
Di seguito la sbrodolata del changelog:
Batocera 39 - 2024/03/07 - Painted Lady
Special Notes
Emulators using Wine now use the Glorious Eggroll custom runner for latest capabilities and compatibility.
Your previously saved games are still maintained in `/userdata/saves/` in their associated bottle for the afftected emulators Xenia, BigPemu, FPinball & Model2Emu.
Future WINE bottles are now provisioned here: `/userdata/system/wine-bottles` under their respective system name. Xbox360 emulators (Xenia & Xenai-Canary) have now moved to support VKD3D (D3D12 to Vulkan) for exanded compatibility by default with the previous native Vulkan available as an option.
New saves will be in `/userdata/saves/xbox360` where you can transfer your previous saves to continue gaming where you left off. You can then free up space by removing your previous WINE bottles from `userdata/saves` respectively after starting each emulator and forming the new WINE bottle accordingly.
If you have used squashfs for your Windows games you can choose to unsquash & recreate the bottle with the new runner.
Enhanced Secure Boot support for x86_64 systems requires interaction with the system's Trusted Platform Module (TPM) even when Secure Boot is disabled.
When booting v39 or later you may need to either disable the TPM or acknowledge the intention to boot Batocera when presented with the blue "Boot Option Restoration" screen.
See https://wiki.batocera.org/secureboot#tpm for more detailed instructions.
Hardware
Initial support for the AYN Loki MiniPro (Speakers not working)
Initial support for the Anbernic RG353V
Initial support for the ASUS ROG Ally
Initial support for the Raspberry Pi 5
Initial support for the Steam Deck OLED
Support for Thunderbolt 3 / USB4 eGPU chassis
Initial support for various RK3568 boards (Rock-3a, Firefly-ROC-PC, Odroid-M1, Anbernic-RG353P, Anbernic-RG353PS, Anbernic-RG353V, Anbernic-RG353V-v2, Anbernic-RG353VS, Anbernic-RG503)
Le-Potato v2 board support
Added
XEMU ES seting for Vsync.
ES setting to automatically detect and enable 16:9 aspect ratio for libretro cores if game suports it.
N64 ES setting to automatically detect and enable rumble pak if game supports it.
Additional sound ES settings for sega libretro cores.
Automatically remap inputs by guid/device name for n64 style controllers and 6 face button controllers.
Added auto-mapping ES setting for 6 face button style controllers for genesisplusgx and picodrive libretro cores.
Additional frame limit options to RPCS3.
New Powermode ES setting. Adjusts cpu governor/system power usage while in-game.
New TDP setting to adjust TDP wattage values of supported Ryzen Mobile Series CPU's per system or globally.
Additional ES controller settings for Dolphin.
DPLII/Surround Sound ES setting for Dolphin. Note there is a mild performance cost.
The Force Engine: Play Dark Forces with enhanced graphics.
IORTCW: Play Return to Castle Wolfenstein with enhanced graphics.
Fallout Community Edition: Play the original Fallout game.
Fallout 2 Community Edition: Play the original Fallout 2 game.
DXX-Rebirth: Play Descent 1 & 2 with enhanced graphics.
Added RetroAchievements for Uzebox and NeoGeo CD
ETLegacy: play Wolfenstein: Enemy Territory online multiplayer game with enhanced graphics.
Konami Justifier / Hyper Blaster light gun in PCSX reARMed core
Not compatible with nuvee GunCon patch, use clean ROM.
Sonic 3 A.I.R. (Angel Island Revisited) port.
New supported steering wheels:
Logitech : Driving Force, G27, G29, G920, G923 (PS4), Momo
Thrustmaster : T300RS, Ferrari 458 Spider
HORI Racing Wheel APEX
MOZA Racing R9
More steering wheel support :
Out of the box steering wheel optimization for Atomiswave, Dreamcast, N64, Naomi, Naomi 2, GameCube, PS2, Saturn
Initial support for Wii, PSX, MAME, Xbox
Automatically set wheels on first players pads when playing wheel games
Add settings for wheel deadzones, maximum rotation angle, midzone per game and system
Spinner support:
Atari Classic joystick: the rudder is seen as a spinner
Ayn Loki Zero: support for on-board LEDs (and light effect on retroachievements unlocked)
Sonic Mania port.
OpenBor 4 (7533 build)
Content downloader: Batocera hosted content can now show thumbnails
Initial support for Retro Shooter Lightgun
Press and hold rear left button for 3s to start calibration
Added zramswap service
Enable swap on rpi through rpi3 to improve suppport for low-memory
variants e.g. Zero 2W
Support for third-party Wiimotes
Enable the wiimote3rdparty service in SYSTEM -> SERVICES
Hotkey+south padtokey for pcsx2 OSD menu
Language: Vietnamese
Support CONFIGS@ mount point in S11share
Calibration for GunCon3 (press and hold B2 for 3 seconds)
Fixed
Yabasanshiro input mapping fix.
RPCS3 Async texture ES setting was not being applied.
Dolphin bug preventing wii pad profiles working.
Dolphin bug that prevented full range of analog trigger axis being used.
Flycast per pixel sorting option if renderer not explicitly set
Bug preventing scraping of msx-family systems
Missing mouse cursor for known iOS soniccd rom originally requiring touchscreen input
Bug preventing passing command line options to ES unless on xorg-based system
Install-to-disk progress dialog stopping around 31% of download
Install-to-disk redownloading image even when a copy is already downloaded
Scraping wrong system (c64) for cplus4 and pet
Missing automount of partitions on NVMe drives in /media
Initialization data was too large for /userdata on RAMdisk
Nvidia Prime defaulting to provider 1 when it could be another provider.
AMD Prime defaulting to provider 1 when it could be another provider.
Sinden Lightgun border not showing on 4K resolution in model2 gun games
ES script logs clobbering game logs #1666
Dolphin does not use Motion Control on DualSense controllers when selected in ES.
Supermodel gun games failing when number of guns were more than the number of controllers
CUSTOMESOPTIONS could not be set when not running xorg #10220
ANYEXTERNAL storage was not functioning in certain scenarios #3455
Hostname was not sent to DHCP server and hostnames from DHCP were not honored #7502
Fixed retroachivements for pcsx2 and duckstation
Restore missing /sbin/hwclock binary
Daphne symlink failing
Emulators failing if Vulkan API is selected and no Vulkan capable GPU is in the system. We now fallback to OpenGL where possible.
Changed
RPCS3 SPU cache enabled by default.
Changes made to Mupen64plus joystick sensitivity and deadzone.
L|R activate in-game "Z" input in Dolphin for GC controllers/GC games if controller has L+R inputs mapped.
PS2 BIOS files should be put in /userdata/bios/ps2
Migrated C-Dogs SDL (cdogs) assets to content downloader
Migrated Super Mario War (superbroswar) assets to content downloader
Default pad order now in emulationstation is hardware dependant (so the same at each boot)
Support x86_64 build on systems with x64 cpu but only ia32 UEFI
Add wsdd for system discovery in "Network" panel on Windows without legacy SMB1 protocols
Send hostname to DHCP server, and allow for dynamically configured hostname from DHCP
Streamlined x86_64 Secure Boot support
Wii gun games now 100% playable with light guns (based on 5 buttons mapping)
Enable performance governor by default on Raspberry_Pi_Zero_2_W_Rev_1_0
Game assets for cdogs and superbroswar migrated to content downloader
Improved workaround for mounting NTFS volumes
Batocera will now automatically choose the discrete GPU (in a multi-GPU system) for Vulkan
EmulationStation: new default settings for the Carbon theme
Updated
Retroarch to 1.16.0.3
GroovyMAME 0.261 - Switchres 2.002z
DosBox-X to 2023.10.6
Libretro-FBNeo to Oct 9, 2023
DevilutionX to 1.5.1
PPSSPP (standalone) and lr-ppsspp to v1.17
Libretro-MAME to 0.261
Libretro-Picodrive to Aug 11, 2023
Libretro-Genesis-Plus-GX to Sep 11, 2023
Libretro-PCSX-ReARMed to Oct 9, 2023
Fheroes2 to 1.0.9
BigPEmu to 1.094
Cemu to 2.0-65
Citra to nightly-2054
Dolphin to 5.0-20840
Flycast to 17th Dec build
Libretro-Flycast to 17th Dec build
MelonDS to Oct 12, 2023
PCSX2 to v1.7.5531
Play! to Nov 30, 2023 build
Python Pygame2 to 2.5.2
Python Pyxel to v1.9.18
RPCS3 to 0.0.30
Ruffle to nightly-2023-10-13
Solarus Engine to Oct 2, 2023
Vita3k to Dec 26 build
Xemu to v0.7.118
Xenia to v1.0.2808
Xenia Canary to 49d4460 (Jan 11 build)
ECWolf to 1.5pre
EDuke32 to Oct 07, 2023 build
Libretro-A5200 to Aug 18th build
Libretro-Atari800 to Aug 1st build
Libretro-Beetle-Lynx to Jul 22, 2023 build
Libretro-Beetle-PCE to Oct 6, 2023 build
Libretro-Beetle-PCE-Fast to Oct 6, 2023 build
Libretro-Beetle-PCFX to May 28, 2023 build
Libretro-Beetle-PSX to Oct 13, 2023 build
Libretro-Beetle-Saturn to May 28, 2023 build
Libretro-Beetle-Supergrafx to Oct 6, 2023 build
Libretro-Beetle-WSwan to May 27, 2023 build
Libretro-Bluemsx to Apr 18, 2023 build
Libretro-Bsnes to Oct 20, 2023 build
Libretro-Cap32 4.5.4
Libretro-ChaiLove to Sep 30, 2023 build
Libretro-Craft to May 28, 2023 build
Libretro-Desmume to Oct 6, 2023 build
GZDoom to g4.11.3
Libretro-DosBox-Pure to 0.9.9
Libretro-Ecwolf to Jul 18, 2023 build
Libretro-Fake08 to Oct 19, 2023 build
Libretro-Fceumm to Sep 17, 2023 build
Libretro-FMSX to Apr 18, 2023 build
Libretro-Freeintv to Apr 18, 2023 build
Libretro-Fuse to Jun 24, 2023 build
Libretro-Gambatte to Sep 29, 2023 build
Libretro-Gearsystem to Oct 23, 2023 build
Libretro-Genesisplusgx-Wide to Sep 16, 2023 build
Libretro-GPSP to Oct 7, 2023 build
Libretro-GW to May 28, 2023 build
Libretro-Handy to Aug 20, 2023 build
Libretro-Hatari to Sep 30, 2023 build
Libretro-iMame to Apr 26, 2023 build
Libretro-Kronos to 2.6.1
Libretro-Lutro to May 30, 2023 build
Libretro-Mame2003-plus to Oct 23, 2023 build
Libretro-Mesen to May 21, 2023 build
Libretro-MGBA to Oct 26, 2023 build
Libretro-Minivmac to Dec 7, 2022 build
Libretro-MrBoom to v5.3
Libretro-NEOCD to Feb 22, 2023 build
Libretro-Nestopia to May 28, 2023 build
Libretro-Opera to Jul 31, 2023 build
Libretro-ProSystem to Aug 18, 2023 build
Libretro-PUAE to Oct 15, 2023 build
Libretro-Scummvm to Nov 27, 2023 build
Libretro-Snes9x to Oct 13, 2023 build
Libretro-Stella to Oct 26, 2023 build
Libretro-MAME to 0.260
Sonic CD to Dec 2, 2023 build
Sonic 2013 to Dec 2, 2023 build
Duckstation to Dec 21, 2023 build
ScummVM to 2.8
Redream to 1.5.0-1106
Raze to 1.9.1
System
Linux kernel to 6.7.2
Mesa to 23.3.4
Proton & Lutris replaced by the Glorious Eggroll custom WINE runner
Wine Tricks to 20240105
FAudio to 23.10
Nvidia production driver to 545.29.06
Nvidia legacy driver to 470.223.02
SDL2 to 2.28.5
Sound Open Firmware to 2023.12
Bluez to 5.71
Added tree utility
VKD3D-Proton to 2.11.1
Host-XA to 2.4.0
Pipewire to 1.0.0
Xorg Server to 21.1.10
XWayaland to 23.2.3
QT 6.6.1
Vulkan stack to support 1.3.275
Special Notes
Hardware
Added
MOZA Racing R9
Spinner support:
Sonic Mania port.
Fixed
Changed
Updated
Fheroes2 to 1.0.9
BigPEmu to 1.094
Cemu to 2.0-65
PCSX2 to v1.7.5531
RPCS3 to 0.0.30
Xemu to v0.7.118
Xenia to v1.0.2808
ECWolf to 1.5pre
GZDoom to g4.11.3
ScummVM to 2.8
Raze to 1.9.1
System
Mesa to 23.3.4
FAudio to 23.10
SDL2 to 2.28.5
Bluez to 5.71
Added tree utility
Host-XA to 2.4.0
Pipewire to 1.0.0
XWayaland to 23.2.3
QT 6.6.1
- SuperMagoAlex
- Città: LaSpezia
- Grazie Inviati: 12 volte
- Grazie Ricevuti: 40 volte
Re: Batocera 39
Per utilizzarlo su crt bisogna seguire questa procedura https://wiki.batocera.org/batocera-and-crt-old
oppure esistono versioni già adattate?
- Città: Mondovi
- Grazie Inviati: 143 volte
- Grazie Ricevuti: 110 volte
Re: Batocera 39
Ciao @SuperMagoAlex
Io per la versione 38 di Batocera avevo utilizzato con successo questo script
https://github.com/ZFEbHVUE/Build-CRT-1 ... a/releases
Vediamo se @Gothrek conferma che si possa usare anche per la 39.
Sempre interessantissima ogni nuova uscita di Batocera; leggendo il changelog, così di primo acchito, non vedo grosse implementazioni che mi possano interessare, per cui al momento rimarrò sulla versione 38 che sta andando benissimo.
Certamente ci sono versioni degli emulatori più aggiornate...vabbè...magari più avanti farò una prova con un altro hard disk di backup
Re: Batocera 39
hanno spinto un po sui volanti e aggiornato/aggiunto driver video, il che porta a maggiori compatibilità, cosi come la dolphin.
Questo sono le cose che per me sono le principali.
Re: Batocera 39
per lo script al momento c'è in release fino alla 38 e una preview della 39, mando un messaggio per capire se modificando la 38 puo' andar bene o se ci sono modifiche nella 39
Re: Batocera 39
L'altro giorno mi sono reso conto che i giochi ps2 non partono più dopo l'aggiornamento alla 39, dando un errore sul BIOS presumo, qualcuno ne sa qualcosa?
- Città: Mondovi
Re: Batocera 39
Ciao, mi pare che nel changelog della versione 39 sia specificato che i bios della PlayStation 2 rimangono gli stessi della versione 38, ma devono essere messi in una cartella diversa, ovvero in userdata/bios/ps2
- LucaS75
- Città: Milano
- Grazie Inviati: 8 volte
Re: Batocera 39
Ciao, per la 39 ho visto che nelle note dello script
https://github.com/ZFEbHVUE/Batocera-CR ... t/releases
è comparso un "see link below for v39 support" che rimanda a:
https://github.com/ZFEbHVUE/Batocera-CR ... nection.md
(personalmente non ancora testato)
Re: Batocera 39
non so dove postare un problema con la versione 39 , per non aprire un nuovo post provo a chiedere qua:
ho installato la v39 su RPI3+b e non mi vede il wifi di casa, il router e la linea è SKY , qualcuno ha avuto lo stesso problema ? se si come avete risolto ?
- Città: Mondovi
Re: Batocera 39
Ciao amico, posso dirti che con la versione 39 di Batocera non ho mai avuto grandi problemi a livello di wi-fi (uso un dongle USB che appunto capta il Wi-Fi di casa).
A volte è capitato che non agganciasse il segnale ed ho dovuto riavviare Batocera oppure semplicemente disattivare/riattivare il WiFi dal menù di Batocera
Re: Batocera 39
dopo aver letto in internet che il router di sky fa schifo , dopo svariati riavvii di tutto, dopo che mi è andata via la luce , non so cosa sia successo ma adesso vede la rete e ... vai di scrrapper e impostazioni varie.
grazie del supporto.
Re: Batocera 39
dopo aver risolto il problema col router di sky, ho dovuto far cambiare il canale wifi da "13" a "1" e lo fanno loro "online" perche il router non me lo faceva cambiare a me, ho smanettato un pò fino a Dragon's Lair, lo vedo in un angolo della tv e non riesco a centrarlo in 4:3, lo riesco a vedere a tutto schermo solo in 16:9, ho cambiato di tutto ma niente 4:3 a tutto schermo, qualcuno per caso ha risolto questo problema? potreste dirmi come?
poi un altra cosa sul gioco, mi sembra che funzioni solo con le mosse Sidam, un pò "strane", io ero abituato alle mosse dell'originale, come dovrei fare per averlo con le mosse dell'originale? ho provato varie "immagini" ma niente da fare, dov'è il problema ?
- Città: Mondovi
Re: Batocera 39
Ciao @larasa .
Ammesso che possano esserti utili, linko un paio di video tutorial sul discorso Batocera - Daphne
https://youtu.be/a3jWOk-It8c?si=vVuN-Uxhw-SRuTAw
https://youtu.be/5zvBGxDoAvA?si=0Nrd-HnDwm5KJd4O
Purtroppo di mio non riesco a dirti nulla dato che, ad ora, i laser games su Batocera non li ho ancora affrontati
