15hz da Raspberry
simone07
Città: Bologna
Re: 15hz da Raspberry
Messaggio da simone07 »
Tox Nox Fox ha scritto: 17/04/2022, 21:40
Ho un aggiornamento:
ho inserito una vecchia Sd che mi aveva configurato un ragazzo, priva di Rom.
VEDO, il monitor sfarfalla dall'alto al basso ma si vede !!!
Quindi la scheda è perfettamente funzionante, il Crt pure!
quindi da questa vecchia sd ho estratto il config che incollo sotto, se riesco a mettere queste configurazioni sull'altra sd (perfettamente configurata) ci sono!
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
gpu_mem_256=128
gpu_mem_512=256
gpu_mem_1024=256
overscan_scale=1
dtparam=i2c_vc=on
audio_pwm_mode=3
dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
disable_audio_dither=1
dtoverlay=vga666,mode6
enable_dpi_lcd=1
display_default_lcd=1
dpi_output_format=6
dpi_group=2
dpi_mode=87
hdmi_timings=480 1 14 45 56 300 1 10 5 5 0 0 0 60 0 9600000 1
#CRT
dtoverlay=act-led,gpio=27,activelow=on
gpio=26=op,dl
Che cambia dall'altro config ?
simone07
Città: Bologna
Tox Nox Fox ha scritto: 17/04/2022, 22:00 Che cambia dall'altro config ?
Bella domanda, apparentemente nulla se non una poca cosa sull'audio.
comunque sono arrivato a questo punto (Solo grazie a te!!):
Ho copiato questo config sulla sd configurata perfettamente e VEDO QUALCOSA A VIDEO!!
non sono quindi arrivato a segno, perchè ho ancora un problema....
praticamente vedo l'immagine a video, ma l'immagine corre dall'alto al basso del monitor continuamente.... da cosa è dovuto?
da configurazione sul Config oppure dalle "levette" dietro al crt secondo te?
Può essere che devi regolare leggermente il monitor sul verticale
simone07
Città: Bologna
Tox Nox Fox ha scritto: 17/04/2022, 22:08 Può essere che devi regolare leggermente il monitor sul verticale
Sono il tuo stress ....mi scuso tanto, davvero, ma insieme stiamo facendo passi da gigante.
Ho "bloccato" l'immagine, avevi ragione... era una regolazione sul retro del verticale.
Ora ho ultimi 2 problemi:
1) immagine non nitida, quasi da veder tutto scuro quasi a non vedere. Ti mando una foto qui di quel che vedo
2) tasti, ovviamente i tasti non corrispondono ai miei tasti de cabinet… come li setto?
Ho provato a collegare una tastiera usb e mi fa scorrere il menu da destra a sinistra facendomi navigare tra le consolle disponibili.
I tasti li setti dal menù di retroarch
L'immagine da schifo
C'è qualcosa che non va come dovrebbe
Hai mosso i trimmer dietro al monitor ?
simone07
Città: Bologna
Tox Nox Fox ha scritto: 17/04/2022, 23:33 I tasti li setti dal menù di retroarch
Si, ammetto di aver mosso i trimmer dietro al crt,
Ho due ghiere sulla destra
Le classiche 8 ghiere per v.hamp h.hamp ecc
E altre 4 ghiere subito dietro il crt
Sinceramente non saprei quale muovere.
Vorrei ci fosse una sorta di menu di taratura, esiste?
simone07
Città: Bologna
Innanzitutto... GRAZIE per l'aiuto che tutto ieri pomeriggio mi hai dato!
ahimè non sono riuscito a regolare il video, l'immagine sul CRT è tutta molto molto scura e quindi inutilizzabile.
riscontro un'anomalia... se attacco il pc con su il MAME... il crt si vede bene ed è giocabile, se metto su il raspberry è tutto scuro.... ma come può essere?
Fai una prova
Ci sono 3 trimmer sulla jammapi che servono per regolare i colori
Girali con un cacciavite e proviamo a dare più colore dalla jammapi
simone07
Città: Bologna
Tox Nox Fox ha scritto: 18/04/2022, 20:33 Fai una prova
Wow! Non lo sapevo!
Posso farlo con tutto in funzione o giro e poi accendo?
Meglio una domanda in piu piuttosto che una scheda bruciata :-)
Puoi farlo mentre è acceso
simone07
Città: Bologna
Tox Nox Fox ha scritto: 18/04/2022, 21:05 Puoi farlo mentre è acceso
Girate le tre viti a stella, la situazione possiamo dire che è rimasta pressoché identica…. Schermo al 90% nero con a fatica si vedono le scritte.
Audio ok, girando le viti è migliorata la resa ma di pochissimo….
Non so più dove sbatter la testa mi sa
A questo punto mi viene il dubbio che la jammapi sia difettosa
simone07
Città: Bologna
Tox Nox Fox ha scritto: 18/04/2022, 21:52 A questo punto mi viene il dubbio che la jammapi sia difettosa
Posso spedirla a chiunque a mie spese per farla revisionare… hai consigli?
Grazie per tutto quel che stai facendo per me
Sempre a bini
Che hai già contattato 🙂
simone07
Città: Bologna
Tox Nox Fox ha scritto: 19/04/2022, 12:38 Sempre a bini
esattamente, e mi ha già risposto!
Questo Forum è fatto davvero da grandi persone! Competenti, cordiali e pronte ad aiutare!
COMPLIMENTI!
vorrei contribuire con una donazione, come posso fare?
simone07
Città: Bologna
Tox Nox Fox ha scritto: 19/04/2022, 12:54 Qua
https://www.arcadeitalia.net/donation
<-on_lol->
FATTO! Donazione effettuata!
