Nel frattanto, quello che ritengo il miglior frontend con emulstation rilascia una nuova release.
Nessun altro rilascia cosi tanti aggiornamenti l'anno vista la comunità che ci lavora!!! Tra l'altro in questa versione supporta nativamente i 15khz e lo scraping del nostro ArcadeDB (@motoschifo )
Di seguito le novità di questa:
warning : rpi4 is now running in 64 bits mode. you cannot upgrade from 29 without doing a simple manual action. To upgrade from 29 and before :
go in the upgrade menu, choose beta and upgrade (behind, this is the stable version, but we want to be sure you'll do action 2).
put you sdcard into a pc. remove the file config.txt. rename config64.txt to config.txt.
odroid go super support
Orange Pi PC support (Allwinner H3)
add: MelonDS libretro core on (x86_64/ RPI4/ Odroid C4/ Odroid N2/ VIM3)
add: Sega Model 3 support via Supermodel emulator (x86_64 for now)
add: SDLPoP (Prince of Persia)
add: DevilutionX (Diablo 1)
add: Xash3D-FWGS (Half-Life 1). Currently supports the following games:
Half-Life, including Blue Shift and Opposing Force.
Deathmatch Classic.
Several mods (https://github.com/FWGS/hlsdk-xash3d/bl ... s/moddef.h)
add: Solarus (RPG game engine)
add: EasyRPG (RPG Maker engine) both standalone and libretro core
add: MAME (standalone) 0.228 with ARCADE64 filter list and GroovyMame 15 kHz patches
add: Hatari (standalone) 2.3.1
add: Dosbox-Pure libretro core
add: Fairchild Channel-F
add: Sharp X1
add: Redream for x86_64
add: Mugen for x86_64
add: Ruffle (Adobe Flash player Emulator) for x86_64
add: LightSpark (Adobe Flash player Emulator) for x86_64
add: Kernel 15 kHz patch
add: Pi 400 support
add: Wine Proton (For more compatibility)
add: MF (For Wine more games compatibility)
add: New systems supported by theBezelProject
add: Cymraeg language (cy_GB)
add: pcsx2 (ps2) up to 8 players
es: Rewritten RetroAchievements :
Rewritten user RetroAchievements screen
Launch games from RetroAchievements screen
New per game RetroAchievements screen
Add RetroAchievements auto collection
Add RetroAchievements filter ( for searches & custom collections )
Add RetroAchievements icon in gamelists
Full indexation of games hashes
es: Add SaveState manager for libretro cores supporting save states. Add SHOW SAVE SNAPSHOTS to AUTO SAVE/LOAD option : This value allows to always open the savestate manager before launching a game
es: Scrapers :
Add ArcadeDB scraper
Screenscaper : Add "map" & "box background" option
TheGamesDB scraper : Add scrap of screenshots, fanarts, wheels, boxes backgrounds & titleshots
Manual scraping : Show results from all available scrapers
es: ImageViewer : Add "zoomable" mode for pages & maps
es: ImageViewer : Add support for Cbz format + Add preview of Cbz files in imageviewer gamelists.
es: ImageViewer : Add "Library" system. This systems is designed to contain cbz ( or pdf ) files of magazines & books.
es: Add "Vertical Arcade" auto-collection + Vertical game filter
es: Add a notification when a new controller is connected / disconnected
es: Load custom additionnal/replacement config files from es_systems_*.cfg files
es: Rewritten md5 / crc calculations for zip files ( using internal zip library )
es: OpenGLES 2.0 support ( for boards supporting it )
bump: many libretro cores
bump: FAudio (Wine) to 21.01
bump: Dosbox-X to 0.83.9
bump: Linux 5.10.x LTS kernel series for x86, x86_64 and mainline supported aarch64 & arm SOC's
bump: Lutris (Wine) to 6.0
bump: DXVK (Wine) to 1.7.3
bump: VKD3D-Proton (Wine) to 2.1
bump: Mesa3D to 20.3.4
bump: Pygame to 2.0.1
bump: Cemu to 1.22.5
bump: MAME to 0.228
bump: RPCS3 to 0.0.14
bump: PCSX2 (performances increased)
bump: WinBTRFS Driver to 1.7.6
fix: USB boot on RPi3 and RPi4
fix: set mac eth addr for vim3
fix: trash on file manager
fix: resizing issue with 2TB or larger drives (now 4k block size)
Batocera 30 release 6/3/2021 15khz e scraping su ArcadeDB
Re: Batocera 30 release 6/3/2021 15khz e scraping su ArcadeDB
ciao , ci sono test o altre informazioni in merito ai 15khz ? necessita di particolari schede video ? lo reputo il migliore frontand in circolazione e se ci fosse la possibilità di collegarlo al crt avrebbero messo il colpo del ko a tutti gli altri .
ciao, non ho visto specifiche sulle schede video dove sotto linux è tutto un pò più facile.
Concordo circa la completezza del frontend, per i 15khz utilzza groovymame in tutto e per tutto.
ps per favore aggiorna l'avatar di default.
se la pupa (inteso come nata da poco ) mi lascia questo weekend vediamo di aggiornare e provare il tutto.
- Andreaxfactor
Ciao qualcuno ha provato? Se capisco bene batocera utilizzerebbe in default il segnale a 15khz senza bisogno di software o altri driver?
si ci sono diversi topic aperti, da quella versione in poi include groovy amme e switchres per uscire a 15khz e poter configurare i giochi con la risoluzione nativa.Andreaxfactor ha scritto: ↑19/08/2022, 8:15 Ciao qualcuno ha provato? Se capisco bene batocera utilizzerebbe in default il segnale a 15khz senza bisogno di software o altri driver?
dai un occhio a quelli già aperti, se hai dubbi sono qui, io ed altri lo usiamo regolarmente.
- Andreaxfactor
