RGBuntu...proviamolo..sembra carino
TheBaro
Amministratore
Amministratore
Grazie Inviati: 6 volte
Messaggio da TheBaro »
Ciao Ragazzi...
ho trovato in rete questo frontend basato su linux che sembra davvero carino..mi ha incuriosito e appena ho 5 minuti lo monto su uno dei miei cab...
Se vi piace e lo provate, qui di seguito possiamo parlarne cosi come fanno i nostri cugini spagnoli! <-gamer->
Dati presi dal loro video:
ENGLISH
Links:
https://mega.nz/file/kgg1AYgb#BZFJ-Cg...​
Password to open pdf file:
rgbuntuforever
Download telegram desktop:
https://desktop.telegram.org/​
If you have any trouble joining a channel, try from here:
https://t.me/joinchat/AAAAAEqG6xVhweR...​
Using winrar to decompress, despite being ZIP's, other programs seem to give errors.
System Requirements:
64-bit CPU or PROCESSOR, Intel or Amd, with the highest possible frequency. What matters most is the performance per core. The vast majority of emulators only use 1 core.
-RAM: 2 gb's. More memory will not be noticed, it will not be used.
-GPU: AMD or ATI graphics card, if you have an nvidia, try to see the result. If you are going to buy one for the occasion that is ATI-AMD. NO recommendations are made, if opinions based on the experience of each.
https://help.ubuntu.com/community/RadeonDriver
in this link you can see a list of compatible cards
-MONITOR OR TV: 15hz, is the requirement. Trifrequency monitor problems, LCD monitor problems. Any TV with SCART input is compatible.
-HARD DRIVE: The minimum size for the system would be 32 gb's, the system occupies about 15, it is recommended to have an SSD disk for the system, a mechanical disk for rom storage. If a single disk can be used for everything, it is NOT what is recommended. The system flies on an ssd, that speed is usable, if it is mounted on a mechanical one, there is a noticeable difference. Already with these data that everyone is free to choose.
-VGA-SCART CABLE: A cable that activates the RGB signal. There are several stores that sell them made, you can also make it yourself. If your cable does not send the necessary voltage to pin 16 to activate the RGB signal (it can be through a USB port, it can be through a molex connector), it will not be valid. It will NOT give a video signal. There are multiple solutions, but you must have a cable that meets minimum conditions.
Versions of the emulators used in RGBUNTU 2.0:
Groovy Mame 0.220
Retroarch 1.8.9
PCSX-Reloaded
PCSX2 1.5.0
PPSSPP 1.9.3
Dolphin 5-0-11991
Flycast r7-rc1-2949
Re: RGBuntu...proviamolo..sembra carino
vediamo se ne vale la pena :D
Se trova due minuti lui significa che siamo in lockdown completo da mesi .. tipo post estinzione dinosauri
TheBaro
Amministratore
Amministratore
ahahah..il mio brontolone pragmatico....e cmq i minuti erano cinque e non due! :P
morenobruni
Città: rovereto
Grazie Inviati: 7 volte
Grazie Ricevuti: 8 volte
Messaggio da morenobruni »
Be... dai io scarico e provo
morenobruni
Città: rovereto
Vi lascio alcune foto devo dire che mi piace ... nei prossimi giorni mi guardo le configurazioni x quanto riguarda il groovymame c'è solo da abitare il swich
bucho74
Grazie Inviati: 9 volte
Messaggio da bucho74 »
Si, ma dove si scarica?
morenobruni
Città: rovereto
Fai la ricerca su google rgbuntu poi fai invito telegram x seguire
bucho74
Ah, ok. Non uso telegram. Non c'è un link diretto?
morenobruni
Città: rovereto
No devi seguire il gruppo sotto invito
gerryilpeloso
Città: ROMA
Messaggio da gerryilpeloso »
Ciao scusa ho scaricato l'iso, e il programma come da guida,pero sbaglio qualcosa e crea il disco avviabile, come hai fatto?
morenobruni
Città: rovereto
Io ho scritto l'immagine con win disk imager su microsd da 128 è la stessa procedura che fai x un'immagine x raspberry xcapirci
gerryilpeloso
Città: ROMA
a ok ora provo
morenobruni
Città: rovereto
Giro ultime foto .. sto facendo prove su tv sony super trinitron da 29 ma non è un gran ché.. devo tirare fuori il mivar da 25 che ho in cantina!!!
@TheBaro
lo ho provato, sinceramente sta parecchio più indietro rispetto a sistemi simili come ad esempio batocera che continuo a preferire, non ha purtroppo niente di nuovo rispetto alle solite combo emulstation+retroarch.
Continuo a preferire Batocera.
TheBaro
Amministratore
Amministratore
mmm..in effetti Batocera non l'ho provato ...certamente tu che li hai provati entrambe, puoi esprimere il tuo giudizio...e poi lo sai che di te mi fido!!di Tox no invece... :P
@morenobruni siamo curiosi delle prove fatte con il tuo mitico mivar!!!aggiornaci! <-w00t-anim->
TheBaro ha scritto: 09/03/2021, 9:41 mmm..in effetti Batocera non l'ho provato ...certamente tu che li hai provati entrambe, puoi esprimere il tuo giudizio...e poi lo sai che di te mi fido!!di Tox no invece... :P
lui è brontolo io dotto :D
Pa0l0ne
Grazie Ricevuti: 29 volte
Messaggio da Pa0l0ne »
Che procedura avete usato per caricarci le rom? Drive usb esterno rinominato "roms" ed i relativi pacchetti scompattati nella sua root?
Inviato dal mio Mi Note 10 Lite utilizzando Tapatalk
morenobruni
Città: rovereto
Io ho fatto tutto da remoto con windows posizionato rom in rgbuntu-systm
morenobruni
Città: rovereto
Queste sono con mivar...anche se alcuni titoli tipo hyper sport .. bubble bobble mi vanno fuori e non riesco a regolare.. provato pure con crtemudrive e groovymame e quest'ultimi sono centrati giusti
Torna a “Frontend”
