Recalbox 7.0 in uscita il 2/10/2020
Il 2/10/2020 verrà rilasciata la versione 7.0 di Recalbox, con la tanto attesa compatibilità per PI4.
Di seguito alcune info sulla release:
Version 7.0
News
Recalbox system is now a firmware, more robust than ever
Brand new update system, easier than ever
Automatic recovery after 3 boots failure
Add Bios checking capabilities to EmulationStation
Add License menu
Adult game filtering in EmulationStation **
New sorting options: Publisher and system-name for all virtual systems **
3 new virtual systems: All-games, Last-Played and Multiplayers **
New virtual systems per genre (RPG, Shoot'em up, Pinballs, ...) */
Region highligting in gamelist (highlight games from your favorite region) **
Add laptop switch external screen function only for x86_64
Add GameCube Bios
Add Nintendo 64DD platform
Add libretro mame for recent mame set
Add EmulationStation event-driver user scripts
Add Search feature and new Arcade-style virtual keyboard
Add Pad-To-Keyboard driver
New ngp & ngpc emulator focused on performance (fast) (libretro-race)
Libretro flycast also available on rpi3, xu4 and x86
Add new system: OpenBOR
Add new system: Solarus
Add opengl on Retroarch for X86(_64)
Bump Amiberry to v3.1.3
Fba_libretro has been renamed to Fbneo
New ports system with Mr. Boom (8-player Bomberman clone) ready to be played
CaveStory is now included and moved to ports
Prboom system has been renamed to Doom and moved to ports
Quake 1 game engine added to ports
2048 game added to ports
Dinothawr game added to ports
Rick Dangerous game added to ports
Flashback game engine added to ports (need full game files to be added)
Wolfenstein 3D game engine added to ports (full game files go all in the same directory)
Dungeon Crawl Stone Soup added to ports
Add libretro's mupen64plus-nx, an improved n64/64dd emulator (rpi only for now)
Add libretro's scummvm version as an alternative to the standalone emulator
Add libretro's pcsx_rearmed on pc too
Improvements
Bump Buildroot to version 2020.02
Bump KODI to Leia 18.5
Share partition is created in exfat on fresh install, which is easier to access from Windows computers
Improve internal Scraper (ScreenScraper):
Faster! Use your ScreenScraper's threads to parallelize workloads
Better! Lots of options, snaps video, and more...
Stronger! Improved reliability and strongness
Improve overall Emulationstation's stability & reliability
Optimize memory requirements of EmulationStation
Optimize EmulationStation boot time (up to 20 times faster!)
Bump DosBox to r4290
Bump ScummVM and map D-pad when no analog available
Bump ResidualVM
Bump Odroid UBOOT to 2017/05 version
Add 8bitdo N30 Pro 2 controller to pre-configured pads/joyticks
Add IPega PG-9037 pad
Improve pad processing in EmulationStation
Bump & fix dolphin emulator
Improved Genre & Region processing in EmulationStation *
Added missing texts into translated texts
Improved french translations
Faster-than-light CRC calculation for netplay
Game sorting and Jump-to-letter are now unicode compatible
Add support for nVidia proprietary drivers version 390 and 440
Bump oricatmos emulator on lastest version
Bump simcoupe emulator
Simplify emulator/core selection UI
Bump retroarch to v1.8.8
Bump retroarch-cheats to v1.8.8
Bump libretro-assets on last version
Bump libretro-cores family
Rename 4do to opera (newer libretro 3do core)
Bump Theodore core (add emulation of Thomson TO7 and TO7/70 computers)
Set vice_x64sc as default c64 emulator + JiffyDOS support
Add support for pupular music formats in EmulationStation
MP3 files
High quality FLAC files
OGG OPUS
Amige Modules (and all derivatives traker formats)
Wave (Raw audio format)
MIDI file (soundfont file required)
More information available in share/music/readme.txt
Add naomigd system for your NAOMI GD-ROM games
Bump AdvanceMame to v3.9
Add volume control to XU4
Improve the management of external screens and selection from recalbox.conf by Chriskt78
Add support for zipped gamelist.xml
Fixes
Fix Odroid XU4 fan issue
Fix Odroid XU4 sound issue
Fix EMMC boot on XU4
Fix x86/x64 Boot videos
Fix music popup crashes
Fix music loop play
Fix netplay popup crashes
Fix apple2 not work on x86/x86_64
Fix fullscreeen on oricatmos and apple2 on x86/x86_64
Fix duplicate folders in Arcade systems
Fix quit menu not being accessible when boot-on-gamelist is on
Fix some bad behaviors in favorite management
Fix reboot Emulationstation with webmanager
Fix volume issues in boot video
Fix REICAST bug on XU4
: Require to scrape missing data using the internal scraper
** : Availailable in both EmulationStation menu and configuration file
rauzer
Città: Udine
Grazie Inviati: 7 volte
Grazie Ricevuti: 13 volte
Re: Recalbox 7.0 in uscita il 2/10/2020
Messaggio da rauzer »
ottimo, testerò il tutto right away!
