HLSL e monitor arcade
- Mokum
- Città: Perugia
Premessa: ho un SEGA New Net City con PC collegato (VGA e 640x480). Essendo a 31khz delle scanlines manco l'ombra.
Ho allora provato ad attivarle da software con HLSL "1" nel file ini del MAME.
Sul monitor del PC non ho alcun problema, su quello del cabinato (stesso identico file ini) semplicemente non appaiono.
Il file ini è questo (ci sono valori che non vanno bene ma li avrei iniziati a modificare se si fossero viste le scanlines):
# CORE SCREEN OPTIONS
brightness 1.1
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
widestretch 0
# OSD VIDEO OPTIONS
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
unevenstretch 1
waitvsync 1
# OSD PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# OSD FULL SCREEN OPTIONS
switchres 0
# OSD ACCELERATED VIDEO OPTIONS
filter 0
prescale 3
# OpenGL-SPECIFIC OPTIONS
glslpath glsl
gl_forcepow2texture 0
gl_notexturerect 0
gl_vbo 1
gl_pbo 1
gl_glsl 0
gl_glsl_filter 1
gl_glsl_sync 0
glsl_shader_mame0 none
glsl_shader_mame1 none
glsl_shader_mame2 none
glsl_shader_mame3 none
glsl_shader_mame4 none
glsl_shader_mame5 none
glsl_shader_mame6 none
glsl_shader_mame7 none
glsl_shader_mame8 none
glsl_shader_mame9 none
glsl_shader_screen0 none
glsl_shader_screen1 none
glsl_shader_screen2 none
glsl_shader_screen3 none
glsl_shader_screen4 none
glsl_shader_screen5 none
glsl_shader_screen6 none
glsl_shader_screen7 none
glsl_shader_screen8 none
glsl_shader_screen9 none
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 1
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 1
hlslpath hlsl
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_write
hlsl_snap_width 1920
hlsl_snap_height 1080
shadow_mask_tile_mode 0
shadow_mask_alpha 0.1
shadow_mask_x_count 640
shadow_mask_y_count 480
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
shadow_mask_uoffset 0.0
shadow_mask_voffset 0.0s
curvature 0.00
round_corner 0.00
smooth_border 0.00
reflection 0.0
vignetting 0.0
scanline_alpha 1.0
scanline_size 1.0
scanline_height 1.0
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.05
hum_bar_alpha 0.0
defocus 0.0,0.0
converge_x 0.2,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.2,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.0
offset -0.15,-0.16,-0.16
scale 1.15,1.16,1.16
power 1.1,0.95,0.8
floor 0.0,0.0,0.0
phosphor_life 0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable 0
yiq_jitter 0.0
yiq_cc 3.57954545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale 0.8
vector_length_ratio 500.0
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode 0
bloom_scale 0.1
bloom_overdrive 1.0,1.0,1.0
bloom_lvl0_weight 1.0
bloom_lvl1_weight 0.21
bloom_lvl2_weight 0.19
bloom_lvl3_weight 0.17
bloom_lvl4_weight 0.15
bloom_lvl5_weight 0.14
bloom_lvl6_weight 0.13
bloom_lvl7_weight 0.12
bloom_lvl8_weight 0.11
bloom_lvl9_weight 0.10
bloom_lvl10_weight 0.09
Secondo voi perché? Ho copiato anche tutti i file della cartella artwork quindi non credo stia lì il problema...
brightness 1.1
contrast 1.0
gamma 1.0
effect none
widestretch 0
# OSD VIDEO OPTIONS
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
unevenstretch 1
waitvsync 1
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
switchres 0
filter 0
prescale 3
glslpath glsl
gl_notexturerect 0
gl_vbo 1
gl_pbo 1
gl_glsl 0
gl_glsl_filter 1
gl_glsl_sync 0
hwstretch 1
hlsl_enable 1
hlslpath hlsl
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_write
curvature 0.00
round_corner 0.00
smooth_border 0.00
reflection 0.0
vignetting 0.0
scanline_alpha 1.0
scanline_size 1.0
scanline_height 1.0
hum_bar_alpha 0.0
defocus 0.0,0.0
saturation 1.0
power 1.1,0.95,0.8
floor 0.0,0.0,0.0
yiq_enable 0
yiq_jitter 0.0
yiq_cc 3.57954545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
bloom_blend_mode 0
bloom_scale 0.1
- Mokum
- Città: Perugia
Re: HLSL e monitor arcade
Davvero nessuno ha mai provato una cosa del genere? Capisco che il 99% avranno il pc collegato ad un monitor 15kHz, ma un disgraziato col 31kHz non c'è?
- Città: Rimini
- Grazie Ricevuti: 181 volte
presente...
non c'è bisogno di attivare hlsl...
Mokum ha scritto:#
effect Real_Scanlines (deve essere presente il relativo png nella cartella artwork)
- Mokum
- Città: Perugia
Provo!DigDug ha scritto:presente...
Mokum ha scritto:#
PS. Ho provato vari file in questo senso, ma sull'LCD, e non mi piacevano granché. Tu potresti passarmi questo tuo file "Real_Scanlines" eventualmente?
- Città: Rimini
eventualmente si, è comunque quello che ha di default mameuifx, sicuro non l'ho cambiato...
considera comunque che con un lcd non avrai mai la stessa resa di un 15khz, neanche con i filtri hlsl (che a me tra l'altro non piacciono)
pierinolartista
- Città: Taranto
Ho letto la vostra discussione. Ho un mamecab con lcd da 19 pollici e non so se è a 15 o 31 kh, sta di fatto che provando l'emulatore sul pc fisso (l'emulatore è mameuifx) funzionano gli effetti mentre sul cab no. Il file scanlines è presente nella cartella e compare anche nominato sul file mame.ini.
Spero possiate aiutarmi grazie.
- Città: Rimini
stai parlando dello stesso pc collegato al monitor del pc fisso e poi sul monitor del mamecab?
per effetti intendi gli hlsl o solo le scanlines?
pierinolartista
- Città: Taranto
Sono due PC differenti e parlo di scanlines.La cosa strana è che se vado su proprietà di una rom le scanlines si attivano,ma andare a modificare le rom un ad uno mi sembra impossibile.
Devi renderle effettive sul file .ini allora vengono attivate SEMPRE!!
in modalita gioco premendo tab puoi modificarle fino a quando non ottieni il risultato voluto
pierinolartista
- Città: Taranto
Sul file mame.ini c'è la voce scanlines (che poi dovrebbe essere il file in artwork nominato scanlines.png)cip060 ha scritto:Devi renderle effettive sul file .ini allora vengono attivate SEMPRE!!
Dove sbaglio?
pierinolartista
- Città: Taranto
Allora: su un mame son riuscito (mancava la cartella "artwork" e prendevo i file da un'altra cartella) mentre un altro (uso due mame diversi perchè uso le rom neogeo aes) mameuifx pur avendo la cartella artwork non attiva il file scanlines pur scrivendolo nel file mame.ini, ma al contrario mi permette di cambiarlo singolarmente per rom.
pierinolartista
- Città: Taranto
Questo è il contenuto del file mame.ini
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# CORE SEARCH PATH OPTIONS
rompath "Z:\HYPERSPIN\Emulators\mame 145\roms"
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath ini
fontpath .
cheatpath cheat
crosshairpath crosshair
pluginspath plugins
languagepath language
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
video_directory video
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
record_timecode 0
exit_after_playback 0
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
snapbilinear 1
statename %g
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
syncrefresh 0
sleep 1
speed 1.0
refreshspeed 0
# CORE RENDER OPTIONS
keepaspect 1
unevenstretch 1
unevenstretchx 0
intoverscan 0
intscalex 0
intscaley 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 1
use_cpanels 1
use_marquees 1
brightness 1.0
contrast 1.0
gamma 1.0
effect scanlines
widestretch 0
# CORE VECTOR OPTIONS
beam_width_min 1.0
beam_width_max 1.0
beam_intensity_weight 0
flicker 0
# CORE SOUND OPTIONS
samplerate 48000
samples 1
volume 0
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
ui_active 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
verbose 0
log 0
oslog 0
debug 0
update_in_pause 0
debugscript
# CORE COMM OPTIONS
comm_localhost 0.0.0.0
comm_localport 15112
comm_remotehost 127.0.0.1
comm_remoteport 15112
# CORE MISC OPTIONS
drc 1
drc_use_c 0
drc_log_uml 0
drc_log_native 0
bios
cheat 0
skip_gameinfo 1
uifont default
ui cabinet
ramsize
confirm_quit 0
ui_mouse 0
autoboot_command
autoboot_delay 0
autoboot_script
console 0
plugins 1
plugin hiscore
noplugin
language English
# OSD KEYBOARD MAPPING OPTIONS
uimodekey SCRLOCK
# OSD FONT OPTIONS
uifontprovider auto
# OSD OUTPUT OPTIONS
output auto
# OSD INPUT OPTIONS
keyboardprovider auto
mouseprovider auto
lightgunprovider auto
joystickprovider auto
# OSD DEBUGGING OPTIONS
debugger auto
debugger_font auto
debugger_font_size 0
watchdog 0
# OSD PERFORMANCE OPTIONS
numprocessors auto
bench 0
# OSD VIDEO OPTIONS
video bgfx
numscreens 1
window 0
maximize 1
waitvsync 0
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
switchres 0
filter 1
prescale 1
glslpath glsl
gl_notexturerect 0
gl_vbo 1
gl_pbo 1
gl_glsl 1
gl_glsl_filter 1
gl_glsl_sync 0
glsl_shader_mame0 "CRT Geom Bloom Vertical"
# OSD SOUND OPTIONS
sound auto
audio_latency 2
# BGFX POST-PROCESSING OPTIONS
bgfx_path bgfx
bgfx_backend auto
bgfx_debug 0
bgfx_screen_chains crt-geom
bgfx_avi_name bgfx.avi
# WINDOWS PERFORMANCE OPTIONS
priority 0
profile 0
# WINDOWS VIDEO OPTIONS
menu 0
hlslpath hlsl
hlsl_enable 1
hlsl_oversampling 0
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_usize 0.1875
shadow_mask_vsize 0.25
distortion 0.0
cubic_distortion 0.0
distort_corner 0.0
round_corner 0.0
smooth_border 0.0
reflection 0.0
vignetting 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 1.0
scanline_variation 1.0
scanline_jitter 0.0
hum_bar_alpha 0.0
defocus 0.0,0.0
converge_x 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
yiq_enable 0
yiq_jitter 0.0
yiq_cc 3.57954545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
vector_beam_smooth 0.0
vector_length_scale 0.5
vector_length_ratio 0.5
bloom_blend_mode 0
bloom_scale 0.0
bloom_lvl1_weight 0.64
bloom_lvl2_weight 0.32
bloom_lvl3_weight 0.16
bloom_lvl4_weight 0.08
bloom_lvl5_weight 0.06
bloom_lvl6_weight 0.04
bloom_lvl7_weight 0.02
bloom_lvl8_weight 0.01
# FULL SCREEN OPTIONS
triplebuffer 0
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# INPUT DEVICE OPTIONS
global_inputs 0
dual_lightgun 0
readconfig 1
writeconfig 0
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath ini
fontpath .
cheatpath cheat
pluginspath plugins
cfg_directory cfg
input_directory inp
state_directory sta
diff_directory diff
state
autosave 0
playback
record
record_timecode 0
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
snapbilinear 1
statename %g
burnin 0
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
syncrefresh 0
sleep 1
speed 1.0
refreshspeed 0
keepaspect 1
unevenstretch 1
unevenstretchx 0
intoverscan 0
intscalex 0
intscaley 0
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 1
use_cpanels 1
use_marquees 1
brightness 1.0
contrast 1.0
gamma 1.0
effect scanlines
widestretch 0
beam_width_min 1.0
beam_width_max 1.0
flicker 0
samplerate 48000
samples 1
volume 0
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
ui_active 0
offscreen_reload 0
joystick_map auto
natural 0
coin_impulse 0
mouse_device mouse
verbose 0
log 0
oslog 0
debug 0
update_in_pause 0
debugscript
# CORE COMM OPTIONS
# CORE MISC OPTIONS
drc 1
drc_use_c 0
drc_log_uml 0
drc_log_native 0
bios
cheat 0
skip_gameinfo 1
uifont default
ui cabinet
ramsize
confirm_quit 0
ui_mouse 0
autoboot_command
autoboot_delay 0
autoboot_script
console 0
plugins 1
plugin hiscore
noplugin
language English
uimodekey SCRLOCK
# OSD FONT OPTIONS
uifontprovider auto
output auto
# OSD INPUT OPTIONS
mouseprovider auto
debugger auto
debugger_font auto
watchdog 0
numprocessors auto
bench 0
# OSD VIDEO OPTIONS
video bgfx
numscreens 1
window 0
maximize 1
waitvsync 0
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
switchres 0
filter 1
prescale 1
glslpath glsl
gl_notexturerect 0
gl_vbo 1
gl_pbo 1
gl_glsl 1
gl_glsl_filter 1
gl_glsl_sync 0
# OSD SOUND OPTIONS
sound auto
audio_latency 2
bgfx_path bgfx
bgfx_backend auto
bgfx_debug 0
priority 0
profile 0
menu 0
hlslpath hlsl
hlsl_enable 1
hlsl_oversampling 0
hlsl_write
distortion 0.0
distort_corner 0.0
round_corner 0.0
smooth_border 0.0
reflection 0.0
vignetting 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 1.0
scanline_jitter 0.0
hum_bar_alpha 0.0
defocus 0.0,0.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
yiq_enable 0
yiq_jitter 0.0
yiq_cc 3.57954545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
bloom_blend_mode 0
bloom_scale 0.0
triplebuffer 0
global_inputs 0
dual_lightgun 0
pierinolartista
- Città: Taranto
Ho risolto: in pratica su MameUIFX devo impostare l'effetto scanlines per il bios (neogeo.zip) solo che a aparità di scanlines c'è una netta differenza tra il Mame che uso per NeoGeo e quello per i restanti giochi. Nel primo le strisce sono gradevoli e non marcate a differenza della seconda.
